Door sill guards
ronald4313jm (08-30-2015)
Received 3,905 Likes
Ronald, how much are you looking to spend? I can find the lighted ones on e-bay for around $300 a door. The non-lighted ones are around $120 each.
If you look at Jaguarparts.com (dealership out of Cleveland, OH), they say the list price of the non-lighted ones is $114 each and they will sell them at a discount of $89 each. The lighted ones are list priced at $325 each and can be had for $275 each.
If you need the part numbers, you can use e-bay to get the numbers. that is how I found the information that I posted here.
Thanks, Thermo. I'm just looking to cover the painted section of the door sills. The car has the brushed metal "jaguar" protectors on the innermost part of the sill. Those are fine, I need protection for the outer painted strips. Our driveway material is made of limestone tailings and it will scratch painted surfaces in a hurry.
Hope I didn't misunderstand your message.
Ronald, it is sounding like your best option is the clear protective film. You can pick it up fairly cheap and it can be applied to a lot of surfaces. Remember, have a heat gun handy. This will allow the film to stretch a little bit and make it better around the irregular shapes that you may want to get around.
3M makes a nice protective tape in various widths. It is often referred to as "helicopter tape" it is used on the leading edges of propellers and helicopter blades to protect them. It is also used on all the leading edges of race cars to protect the paint from grit and oils from the track and other cars. It also removes fairly easy without damaging the surface.
Andrew Fanshawe
04-04-2017 12:51 PM
Andrew Fanshawe
09-14-2015 07:40 PM
