DPF filter
Received 2,266 Likes
The comments on this for the S-Type diesel suggest having it towed to the dealer and a forced regen - but be sure to check the engine oil has no diesel in it and if it has then change the oil. Engine destruction is a real risk, sadly.
How often are you guys seeing any DPF warnings, and is it because your daily commute isn't far enough?
I've yet to see a warning, and my normal commute is only around 23 miles (and a bit stop/start, no real constant speed above 50mph). I've only had the thing since April though.
Kencar
12-21-2016 04:18 PM
Johnken
11-09-2016 02:20 AM
