DRL, my solution.
DRL, my solution.
Hallo you all,
after a long investigation I finally decided to make DRL light myself.
This is the result.
If someone needs specs, please ask.
Sandro
DRL fixed on the grille (closed side)
External view (closed side)
External view (intercooler side)
commander
We take relay power ACC from fuse 10A (the only red) It is a temporised power, when car switched OFF it takes 18 seconds then DRL OFF too.
DRL ON
This is the result.
Sandro
commander
DRL ON
It looks good. I had a similar idea a few months ago but decided against it when I realized I'd be blocking a good portion of airflow to the aux radiator on the passenger side. Definitely looks good. That's really the only position where it would look stock. What brand are the units and what specifically did you hook them to in the fusebox?
JagSupersport (07-12-2018)
Hi all,
the DRL kit is this:
https://www.ebay.it/itm/DRL-CREE-SUP...72.m2749.l2649
To get the +12V i connect the red wire as indicated to the 10A red fuse.
To get the lamp ON/OFF i connect the purple/brown wire to the white drl kit wire from headlight connector.
(I replaced the original 10A fuse with a shunted 10A fuse, you can buy here: Fusibili Uni Lamellari 10 A con Derivazione | Guidoni)
Here the pictures of inbox connection:
Inbox connection
Shunted fuse 10A
0,75mm hole glued and water isolated.
Inbox connection
Shunted fuse 10A
XJ8JR (07-02-2018)
