Drop engine to remove exhaust manifold on 3.0D
Before I even start confirming that I need have a cracked exhaust manifold, I just wanted to know if to replace it, the engine needs removing.
i just removed the EGR cooler which was a tight squeeze. Had smoke coming from LH side of engine. Inlet manifold has to be be changed due to restricted performance and then I discovered a coolant leak which has been resolved but smoke seems to also be coming from below that
