Hello gents,
Recently ECM has been changed on Jaguare xj 2006 also EEPROM changed from old PCM
Car started but with limited performance when you drive it you feel like the car is not taking the order to accelerate dashboard shows "DSC is not available"
I connected SDD I found two permanent error.
U0300-55 internal control module software incomptability.
B1987 pedal forward/rearward motor stalled .
I tried to reprogram ECM but it gives me an error while reading climat control
I programmed REAR control module successfully
Would anybody mind helping me with this problem.
The car parked for 5 months just waiting for new box to arrive from USA.
I am waiting for some help as you know there is no shops specialized in jaguar in libya
Thanks in advance
You've posted in the wrong forum, the car is an XJ6 built 2003-2009. You'll get far better responses if you move it to the forum for X350, X358. Found in the "Modern Jaguars" section.
Thank you guys for replying, ok I posted the problem in the mentioned forum as you requested.
I hooked up charger and the indicator shows green.
Also I replaced the battery.
