ECHO Engine automatic start/stop
I got my first Jaguar few days ago, it has the engine start/stop feature but it did not turn off a single time since I acquired the car. The car is a 2014 model XJ-R.
I am wondering if there is somewhere a setup that I could not find or if there is a problem with the car. I read that one of the conditions for it to operate is the battery charge status, is there a way to find out if the secondary battery is charged or charging? Any other thoughts?
I finally understood how it is working. I can stop the car gracefully without pressing the brake hard and prevent the enginee to stop. If after stopping I press the break a bit harder I can cause the enginee to turn off until the brake is released.
I am wondering if this is normal or if the is an issue with the car. I am waiting to receive the handbook to study it before reaching out the dealer (for clarification, I bought this new car and the dealer forgot to provide the user manual. They shipped the manual but I did not yet receive it)
Question:- Can one override this stop / start crap? We are about to get a 2014 XJL and I really do Not like this feature . . .
Locate the small battery that supplies it and disconnect it. Tape up the connections to be on the safe side and then forget about it.
I recently had a 2014 XF loaner with start/stop last time my car was in for service and actually found it kind of neat. The first time the engine cut out was as I stopped to pull into traffic from the dealership. It took me a second to realize what was happening, but after that, I could anticipate it and also noticed its sensitivity to how I braked. I only had my loaner for a day so the novelty factor was high and didn't disappear. Re-starts were instantaneous. I wonder if a winter would change that a bit?
ECO Start/Stop
Luck
King Fala
Jesse James (08-09-2014)
ECO light on 2014 Jag XJ
The ECO feature is bad but it can be turned off. What's worse is a yellow warning light on the dash when the feature is off. That is a warning light that you cannot get rid of and that is so annoying. I had to put electrical tape on my new dash to cover it up. How ridiculous is that? On a Mercedes S550 the light (green) is on when the feature is on and the light goes off when the feature is off. And the light is between the seats on the floor console. Jag has to give you the option to turn off the feature and turn off the annoying yellow light. Other than this annoying light, the car is great! Help Jag factory!!!!!!!!
I just picked up a 2014 XJL V6 last week, and I can tell you that you are unequivocally incorrect with respect to this model. I see that you have an XJ-R V8 and perhaps that is the difference.
Wolfy
05-28-2024 08:06 AM
99xk8guy
06-05-2023 06:28 AM
