XJ ( X351 ) 2009 - 2019
Econo mode
Old 11-29-2013 | 10:52 AM
XJcat's Avatar
Default Econo mode
Anyone figure out how to disable the economy mode or set it as default. What a ridiculuos thing to put on a performance vehicle. Anyone living in a metropolitan area or near any traffic at all will hate this.
Yes, I know you can push the button to shut off, but you need to do it every time you start car and it is extremely annoying when the economy mode is on, a/c does not work as well when sitting at light or in traffic, same for heat, acceleration is reduced. Just a terrible thing to have coming on as the default. It should be the other way, default is off and if you want economy mode on press the button.
Would love to shut off forever.
Old 11-30-2013 | 04:04 PM
JonnyJag's Avatar
Just disconnect the negitive battery wire to the small battery that is in your trunk/wheel well. This will disable the eco start/stop feature.
Ralph12345 (12-01-2013)
Old 12-02-2013 | 09:31 AM
XJcat's Avatar
Default battery
Is that the only thing that battery runs?
I've never looked but are there two different batteries in the trunk, or just the one you are saying to disconnect the negative from?
Old 12-03-2013 | 09:42 AM
JonnyJag's Avatar
the small battery in the trunk only runs the eco start/stop feature. Disconnect the negitive side and you have disabled the feature. Make sure that you secure the disconnected cable well so it will not accidently reach the battey post.
Old 12-04-2013 | 03:17 PM
XJcat's Avatar
Thanks, going out to disconnect right now.
Old 04-03-2014 | 02:51 PM
rlriegle's Avatar
Default Eco Start Stop Disconnect
I was informed by the Dealer that the smaller battery also transmitted feedback concerning sensor codes and other info. Also that it may be related to the engine warning lamp being illuminated. Disabling might lead to other issues. Does anyone have knowledge to the contrary?
Old 04-04-2014 | 02:17 PM
XJcat's Avatar
Mine has been off since Dec and have had no issues
About to bring in for regular service and I am sure they will tell me it should be connected
max224
06-21-2024 01:17 PM
JaguarLover101
48
06-12-2023 11:28 AM
tampamark
10-11-2015 11:03 PM
ziondio
09-29-2015 02:58 PM
Quick Reply: Econo mode
