XJ ( X351 ) 2009 - 2019
Engine Oil Overfilled
Old 01-23-2018, 08:20 PM
XJ8JR's Avatar
Default Engine Oil Overfilled
So I'm still getting used to the new Jag and it's silly electronic dipstick. I've checked it multiple times over the past week and its always said Level OK, sometimes after sitting for 10 mins or sometimes overnight. Suddenly last night it says Overfilled after the car had been sitting for a few hours. Checked again today after it had been sitting for hours and still says Overfilled.
I guarantee no one has touched this oil. How can it go from OK to Overfilled over the course of a week and a half? Any ideas?
Old 01-24-2018, 01:54 AM
rhomanski's Avatar
Are you losing antifreeze?
That led me to the dipstick for the oil once.
I found my antifreeze in my oil pan.
XJ8JR (01-24-2018)
Old 01-24-2018, 12:17 PM
XJ8JR's Avatar
I'll check that out. Thanks.
Old 01-24-2018, 12:56 PM
Jagxj2014's Avatar
do make sure that you put the correct level of oil, the AWD version takes .5 less than the RWD.
Old 01-24-2018, 01:07 PM
XJ8JR's Avatar
Thanks, but I don't have the AWD and the last oil change was done by the dealer I bought the car from.
Old 01-24-2018, 02:07 PM
XJ8JR's Avatar
Just checked the coolant. Level looks the same as last time. I'll trying siphoning a bit of oil out later and see what the sensor tells me. Has anybody had a faulty sensor on these engines?
Old 01-25-2018, 09:22 AM
Jagxj2014's Avatar
had a sensor gasket leak, but didn't hear many stories about the sensor failing. Though it could be a possibility.
Old 01-25-2018, 12:07 PM
XJ8JR's Avatar
So last night it went back to Level OK all its own, but I ended up siphoning out about a quart just in case. Now it reads 2 hashmarks below Max. I'll keep an eye on it to see how much it fluctuates and then top-off if necessary. I can see this new contraption will take some getting used to.
Old 01-25-2018, 01:52 PM
rhomanski's Avatar
I've always just put in what the manual said. Either 4 quarts or five and it always ended up just a hair under full on the dipstick. I'm guessing that didn't work for this one?
Old 01-25-2018, 02:45 PM
XJ8JR's Avatar
Oil was last changed at the dealership (non-Jag) before sale, so I have no idea how much they did or didn't put in.
Old 01-25-2018, 03:46 PM
XJsss's Avatar
XJ8JR if it were me I would have the oil changed at a dealership very soon as these engines will not last if the proper iol is not used. There are small passages in the lubrication system that can become clogged if the proper iol is not used all the time, IMHO
Old 01-25-2018, 04:08 PM
XJ8JR's Avatar
I'm taking it in this Saturday to have some leaks addressed, so maybe they'll throw in an oil change since they've got to remove the pan anyway. If not, I'll plan on doing it myself afterwards.
Old 01-25-2018, 04:23 PM
JBzXJ40's Avatar
I've only seen the sensor leaking through the O-ring, but haven't seen an actual failure of the sensor itself.
If you're taking it in, they should connect SDD anyway to check for codes - might be a DTC logged for the sensor.
Old 01-25-2018, 04:27 PM
XJ8JR's Avatar
Good idea. I'll bring that up with them.
Old 01-25-2018, 06:36 PM
XJ8JR's Avatar
Just checked the oil again on my lunch break just now and it reads Max again. How can anyone trust these things?
Old 01-25-2018, 06:39 PM
JagGate's Avatar
Are you planning on using the Jag spec oil? You can't change the oil unless you have the oil. It is very hard to find. You can use a blacklight to see if they used the proper oil. I have checked and it does fluoresce under blacklight like they say. Jag charges $150 for an oil change btw.
Sorry just saw about the pan - if they are replacing the pan, I cannot see them reusing the same oil.
Old 01-25-2018, 06:46 PM
XJ8JR's Avatar
I saw in a different thread that Castrol Edge/Titanium meets the Jag specs. Has anyone else confirmed this?
Old 01-25-2018, 06:55 PM
JagGate's Avatar
No not always. The below oil meets the specs. Note that "Jaguar" is actually on the label.
https://www.ebay.com/itm/Castrol-Edg...p2047675.l2557
Old 01-25-2018, 06:57 PM
JagGate's Avatar
I will confirm also that Castrol Edge Titanium does NOT meet Jaguar specs.
Old 01-25-2018, 07:19 PM
XJ8JR's Avatar
I found an old thread on the UK Jag forums with this link:
Amazon Amazon
According to the label, it meets the 925-A spec.
Quick Reply: Engine Oil Overfilled
