Engine rattle on startup (3.0D)
When i start a cold engine i hear a rattle for about 3 seconds. When engine is hot it rattles for 1 second. When i stop it and start immediately again it doesnt rattle. Engine has 150k km. has anyone experienced it? I think it can be a chain tensioner? And it rattles until oil pressure is not up? What you think?
Thanks!
Thanks!
sounds like it may be oil pressure, i'm not sure if Jag uses any chain tensioners that are adjusted by iol pressuer, but this may be what is happening. Are you sure you are using the proper oil as Jag is very particular of the viscosity and that it is the proper specified synthetic oil by Castrol.
asleach2889
03-13-2016 09:07 PM
rsq911
03-12-2016 09:55 PM
