Exhaust tips
Received 3,929 Likes
dragonalfa, odds are, the volume of the tips is going to be much more than that of the exiting pipe of the muffler. So, the tips should offer no restriction to the exiting gases.
The only "negative" that I could possibly think of is that having a single exit on the tail pipe will make for a longer exhaust pipe and potentially help with the suction that the exhaust system creates via the exhaust pulses. But, we are talking a few inches of piping on a 100+ inch long pipe. So, any negative effects will be very minimal, especially once you take into consideration the changes made by the joining of the exhaust pipes and the baffling of the mufflers. Yes, I think things way too far out and into probably more detail than is needed.
Are you sure they will fit? You need to remove one of your existing exhaust tips (it is bolted on and is easy to remove and reinstall) and measure the length, width, and height as well as the diameter of the tip where it bolts onto the tailpipe. Then you have to get the dimensions of the tips on eBay and determine if they will fit. Most "universal fit" tips will be too long or too wide to fit properly in the bumper cut-out.
See: https://www.jaguarforums.com/forum/x...ips-xj-151318/
Good luck!
Try - Spires Technologies Ltd - Spires ? Performance Tuning and Motorsport
I have a set of quad pipes in stainless steel, just remove existing oval end (One Bolt) and just bolt on to the existing pipes where fitted my XJ X351- 2010 -Diesel no problems.
Make me an offer if you wish buy them.
