Finally a night at the Drag strip! Big Jaguar XJ SC 5.0 Racing at 1/4th mi
It's been a while since I hit a 1/4mi drag strip. Unfortunately most tracks near San Diego have closed after covid for whatever reason, and the nearest one is now a long five-hour drive to Bakersfield. It was a busy night with a long wait—four hours for just two runs, didn't help that like on nights when there's a lot of modded civics, they break down at the track and slow things down but that's the way it goes sometimes . Despite the minimal mods on my 2013 XJ SC —crank pulley, intake, ECU& TCU remap (full stock exhaust still) with DA around 1600, car did not perform too badly! Could have pushed more with the 60ft , but ran out of time at midnight. Low 11s definitely can be had with a better 60 ft
Alpha Jag Tuning @alphajagtuning #alphajagtuning
tergitkerd (09-17-2024)
Cool thread. What did it put down on the dyno and what are your AFRs/timing under boost?
I'd be interested in seeing before and after dyno sheets on the stock intake versus your short ram intake. Your intake looks like it takes in hotter (less dense) air under the hood than the stock setup, which takes air from in front of the radiator.
haven't Dynoed this car but probably close to 600 to the wheels . It's not my first rodeo been tuning these for a while! Started back on 4.2 xkr and set some records on that one, then moved on to Denso 5.0 cars with 6 spds set some records with mid to low 10sec cars and now unto newer platform with Bosch 5.0 and 8spds transmission which are in all newer 5.0 cars fpace, ftype, XJ Facebook.com/alphajagtuning plenty of reviews there and plenty of ppl running our remaps if you check on Facebook forums. We do ECU, TCU tuning , have crank and upper pulleys, Intakes and so on..
This one is first year Bosch with 8spd zf8hp as in all new Jaguars up to 2024 with with 5.0
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
Stuart@VelocityAP
12-12-2020 10:13 PM
