Front Splitter kit
As an alternative, consider the lower front bumper apron kit with real carbon fiber center section from Mina Gallery: Speed style Bumper Apron w. Real Carbon Fiber Center for Jaguar XJ Series - Mina Gallery Inc
At US$350 plus shipping, it might be less expensive than the OEM item.
Received 3,915 Likes
I just installed the Mina front splitter/chin spoiler. I cannot say that I am overly impressed. What I got didn't come with any instructions, just a bag with a few screws in it (still not sure what they were for). Granted, I wasn't too worried about the instructions (atleast till I was nearing the end) as I figured it was a fairly simple bolt on thing.
Needless to say, while it doesn't look bad, I think it could be better. The fit of the pieces was not what I would call good. The center section did not have the holes drilled out in it. No biggie. But, if you look at the picture from Mina, that piece seems to sit out at the edge of the bumper where mine seems to sit back about 2 inches. Not to mention that I had to modify the piece to make it fit. It was as if one side was made longer than the other. Granted, I am wondering if it was the intention to not use the factory bolt holes (which the Mina indentions lined right up to), but to drill all new holes to mount the kit on to the car with.
At this point, I can't say that I am overly excited about buying another Mina product. I have installed their exhaust system and those went on without a hitch and would recommend those. But this chin spoiler was a completely different story.
Do you have any pic of it installed? Did you do the carbon fiber?
I was like you and wondered WTH at first.
It took me awhile to realize you don't need to drill any holes just install using the existing hardware. The blank spots where you think they missed drilling holes should be left alone.
I don't think it's meant to be a solid extension of your bumper so it breaks off when you hit something instead of ripping your bumper off but I could be wrong.
I went to the dealer and looked at a few of them installed and it didn't look any better than the Mina one.
I also have their exhaust and love it.
I can only speculate that it is possible because the splitter comes in 3 separate parts. So, recessed centre or not, it can still be installed.
I presume it also works the other way round? (2011 splitter on a 2016 xj)
This is what puzzles me. The pre facelift bumper has a continuous curved profile on the bottom edge whereas the facelifted bumper has forward protrusions on either side with a slightly more recessed edge in the centre. How would the 2016 splitter fit the 2011?
Yes I bought a 2016 front splitter kit comes in 3 parts for the lower part of front bumper.Your right in that all the pictures I examined before purchase the later bumper looked more forward.I took the risk and to my eye it fits perfectly all the holes lined up etc.See picture below
2016 front splitter on 2011 xj
NvmyJag, if I fix it, I am going to have to get a new center section. I trimmed a little bit off of it to make it fit like you see it. If I slide it forward, it will most likely end up with a little gap between the center piece and one corner piece. So, may need to do some looking around and seeing what I can find.
The center section is recessed about an inch as the design in conjunction with the rear spoiler was designed in a wind tunnel for high speed stability. My XJ has the factory speed package and both front and rear aero bits, and also the max speed limit is increased to 174mph. Even my speedometer is different in that at the 6 o'clock position my speedo shows 110mpg and non speed package or XJRs speedos show 90mph at the 6 o'clock position.
@googsy that front splitter is NOT a 2016 kit, don't know where you got it but definitely not for the new front bumper/LED headlight car. IMHO
Thanks XJsss it was advertised as 2016 on eBay brand new and half the price it would normally cost. I bought it as I wanted one desperately and thought if it didn't fit I could somehow modify it so it would.So there's a strong chance the advertiser had his facts wrong. I'm just delighted it fits .
