Fusebox location
Looks way worse than it is.
Remove bottom seat - easy has quick release and couple of connections
Remove back seat - 4 nuts along the bottom and pull the string. Seat moves forward, unplug electrical connections and carry out of car.
Remove C pillar trim, just pulls out.
Remove Rear quater trim, 1 torx bolt and pulls out.
Remove parcel shelf - loosen 1 8mm bolt on each side. Undo 3 quick release plastic screws along the front and pull up and out.
30 mins work.
30 mins work.
jimforrest (uk)
02-28-2019 06:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
