Gearbox Fault & Adaptive Dynamics Fault
Just one additional question?
Does the 8 speed have the same sealing sleeve leak that the 6 speed ZF does?
I ask because the 8 sp fluid change kits do not include the sealing sleeve but they still contain the improved steel pan bolts. So I know the pan bolt problem still exists on the 8 speed.
So far at 42K miles I see no leakage on mine yet.
Interesting thread. I have experienced the same symptoms in one car and similar in another. The first car wasn't a Jaguar, it is a Mercedes SLS Roadster with the Getrag 7DCL750 box.2012 model manufactured August and problems began at 24,000 km with precisely the same symptoms. After just over 2 years trying to find a fix I admitted defeat and have bought a new gearbox, about 20,000 pounds equivalent. I am pretty sure that the actual problem was the control unit. We had replaced a solenoid and another fault emerged. It was better to get a new box and keep the old one as a refurbed spare. A new control unit was about 40% of the new box price.
Now my 2012 XJ 5.0 SC is doing similar things, not when the trans (and fluids) are at operating temp but cold. And includes the engine shutting down. Honestly I don't want to go through this with another car. Does anyone know whether you can get a new control unit, or a new gearbox and what the part number is and approximate cost. It is at a Jag dealer atm and he said a gearbox will be about 20,000 pounds also. I am in NZ and we get ripped off for parts here. I might just put a sequential manual race box into it.
I'm getting a simmilar problem - even opened another thread regarding it. My problem is that the problem accures only when wipers are on - not sure why but wipers are causiong my speedometer to go up by 10mph when thay are working. This causes the Gearbox Fault & Adaptive Dynamics Fault.
Not sure what to get from that.
I understand that - the problem is that there is no error code associated with the fault.
What I've done before was to lube the wiper arm to see if that help - no change.
After that I have changed the whole wiper arm with the new wiper motor - unfortunately no change.
It all looks like a ground problem now - but where should I look .. is there any ground points near the transmission ?
Completely lost.
Completely lost.
#30
I know from the work we did on the Getrag box for the SLS that the control unit and solenoids require an electrical "signal" ie it has to be within a very tight band other the the TCU will think it or something is faulting. So that is what I would be thinking, look for electrical.
The vehicle and probably XJs als o have a voltage regulator(my XJ gearbox issue was actually a worn engine mount, but not this issue). The voltage regulator is a unit on its one(can be part of the alternator assembly in some cars). It can be damaged by an alternator on the way out but not yet failed. The regulator is generally not itself monitored for a fault, so no CEL for that if bad. Faults are generally triggered by a voltage outside programmed parameters. So the voltage regulator can send out voltage spikes if damaged. I changed the alternator about a year ago after a catastrophic failure. Service manager said it may be possible but he knew nothing about regulators. So it is going to the country tech director and no doubt back to manufacturer.
So if your symptoms are similar I would change the regulator(it is cheap). It may save very expensive repairs(or not!). I wonder how many gearboxes have been changed in the world when this may be the issue.
BTW I know about voltage regulators because my 50 year old Piper Navajo has 2, a main and alternate.
#31
#32
There are no codes for the non-computerised voltage regulators from what I understand. Voltage regulators can be combined in the alternator but I think they are computerised and they can throw a code. Maybe there is an electrical issue with the non-computerised ones because of what it does . As a stand alone unit they are only tested with a multi-meter and the test isn't straight forward. I have read some McLaren drivers have experienced the issue I have spoken about.
One of the MB service managers came on a drive with me while he had the diagnostic hooked up about 1.5 years ago. . (This issue went on for about 2.5 years for a range of issues including COVID lock-down and then a 6 month wait for the box, it was going to be 12. ). He actually saw a couple of voltage spikes but he and I didn't understand the significance. At that time the alternator hadn't failed. It is only now piecing it all together that this theory is plausible.
#33
The X351 XJ does have numerous codes for the charging system. You will not see them until the car is scanned with a SDD system.
You knowledge of what you think the your car is doing is of zero help! You must follow what the car is telling you.
There is no other way unless you load the parts canon and start replacing random parts based on your theory's?
Your MB and Mclaren experiences are again of zero value. Focus on YOUR car and it's problems!
#34
