Getting into the trunk when the battery is disconnected
#41
#42
#43
No such panel exists on X351. No mechanical lock anywhere than drivers door.
The factory X351 Service and Repair manual give two options after accessing inside if the cabin with emergency key thru drivers door:
- Option one: Open hood and add power to the power point inside of engine bay fusebox and the press Open Boot button. Nothing else, donīt turn ignition On !! (also descripted on Owners handbook)
- Option two: Remove back seat and rest. There are an plug/wire to power only the boot lock solenoid. This is for the cases that battery are removed, trunk closed and battery Plus terminal shorts to chassis. -> vehcile circuit unusable.
XF is totally different chassis and its more worth to write tricks and hints on XF forum instead of XJ forum where they are unusable.
