Has anyone changed supercharger oil on the x351?
Hi Gents,
The supercharger oil on our cars apparently are not lifetime. I know we have the options of either changing the oil regularly to keep the supercharger healthy or replace the whole supercharger should it die.
I perfer the former one. I have read here that some owners changed theirs on their x350, but I have never come across a post on x351. Does anyone know where the drain hole is? Please shed some lights so I could try it on a x351?
I don't know much about XJs, but I'm guessing the X350 is the 4.2 and the X351 is the 5.0?
Anyway, I do know from the XK and XF threads that changing out the supercharger oil on the 4.2 is a relatively straightforward job as the drain and fill hole is at the front of the SC and on top and not all that difficult to get at, but the 5.0 is a whole other kettle of fish as the drain hole is at the back end on the underside of the SC and the SC must be completely removed before the oil can be changed.
JLR claim that the oil in the Eaton TVS SC is "for life" (it actually says so in the AJ133 Technical Training doc), but this claim is in the same league as the claim that the ZF gearbox fluid is "for life". For the life of the 3/4/5 maybe 6 year warranty maybe, but that's about it!
Nedoerr (03-24-2019)
Nedoerr, can you please enlighten me on this, what is “supercharger isolatir spring service”?
If you have to change the spring drive use the solid one from E bay. I replaced the drive and oil when I changed the timing chain tensioners on my X J .If you have not replaced the timing parts you should think about doing it, It not about if they will fail its when they will fail The tensioners are not suited to 5.0 motor. After examining the tensioners you can see how they fail. So i made a new set of tensioners for the 5.0 using the pawl and ratchet design.
My XJ was built in September of 2012 as a 2013, I have had the guides /tensioners replaced and created this thread for that https://www.jaguarforums.com/forum/x...t-done-214277/, Also the supercharger isolator update was performed on my XJ with the replacement of the nose piece, that, I am quite sure, is not a lubricated part and did not necesitate the removal of the supercharger to perform.
To repair this, they have made a kit that replaces the nose of the supercharger. Most people I’ve heard do it, remove the supercharger to do this, however you may be able to do it by tilting it upwards. Someone with more DIY experience would have to confirm this. Most people also change out the y-shaped coolant tube while they have the supercharger out.
My independent repair shop said that although the pulley should eventually wear to the point of breaking, he has never seen this happen. Usually people bring it in when they hear excessive supercharger noise.
This is not to be confused with the timing chain tensioners. That is a separate Issue covering 2010 models to some 2013 models.
The supercharger isolator coupling goes between the front nose assembly and the supercharger body.It joins the front shaft with 3 dowels to the supercharger shaft 3 dowels there are s 6 hols in the isolator 3 are round and 3 are slotted. 1 of the slotted holes has a spring end that one of the dowels rest against .Over time the coupling gets damaged to the point when you turn the pulley with the belt off you can hear a clunking noise As far as the tensioners go i just replaced the NEW and updated kit that was replaced once before on a land rover this will be the third kit for this vehicle Al so i know 2014 land rover replaced under warranty 40 thousand k so it is not isolated to 2011 2012 years All 5.0 motors.
All the timing parts that was replaced on the Land rovers was of the updated parts new tensioners new tensioner blade with hardened steel insert. The tensioner piston failed collapsed in, so there was no positive stop the distance was 5/8 in between the tensioner and blade witch cased the chain to slip and bend the valves . If you examine the tensioner piston you will know it operates and you will understand that they are prone to failure.On my XK the piston lost its mechanical stop the spring kept the piston out. On startup, the piston spring would compress causing the piston to go in and out until the oil pressure keep the piston extended, once the mechanical round cerclip lock fails the piston spring is not strong enough to stop the chain from losing its tension. I replaced my tensioners with my design.
Wow, I did not expect my supercharger oil change question would extend to need of an isolator spring change and to a tensioner piston failure.
Mine is a 2013 MY14 XJL 5.0sc, with odometer showing 60000km, but I have an impression that the car had actually done more than 60000km, perhaps already 150000km. Do you guys think I should have my supercharger taken out and replace both oil and isolator spring?
The best way of checking the coupling is to remove the supercharger belt and rotate the pulley back and forth it should rotate in the slotted holes and put a load on the spring.If there is a problem you will hear excessive noise.Expect to hear some noise when the dowels rotate in the slots. There are two greased bearing in the front section some times they have to be replaced , or you can bye a new front section with coupling .Look on Aibaba they sell the front assembly.The coupling from Ebay About the oil its up to you, I do not believe in OILED FOR LIFE. Nor do believe in one change every 24 K.The next problem will be the transmission oil 150000 K is to a lot.
Normally, if it's not broken, don't fix it. However this is a known TSB that will eventually require replacement. I'm sure someone will chime in discounting this statement, but I don't think it's common to need to do the supercharger isolator twice. So if you haven't had it done and are removing the supercharger anyway. I personally would do it. The labor for the isolator job is 14 hours according to the TSB, mostly for removing the supercharger. The repair kit can be found from jaguar for ~$650 last I saw (at reno parts or carlsbad parts). I don't know about sourcing from 3rd party retailers on this part yet. I will be looking into this soon as well. See the attached TSB for part numbers and more info.
I can hear my isolator starting to fail. It makes the sound of a small marble bouncing around while in idle (have to listen with the hood open, cant hear it when I'm in the car). When I use a mechanic stethoscope and touch it to the supercharger, it is clear that is where the sound is coming from.
