Has anyone changed supercharger oil on the x351?
#41
The 5.0 S/C engine only has one hose that runs under the supercharger. It comes from the rear of the engine and is clipped to the bottom of the supercharger in a couple of places. It then attaches to the left side of the throttle body (as you look at it from the front of the car) using a ear type clamp. The other side of the throttle body connects to a small hose (same type of ear clamp) that goes into the pigs ear of a set up that finally ends up at the coolant reservoir. I recently changed to the water pump and removed the supercharger on my 2012 XF Supercharged and posted the steps including some pictures of the plumbing. Check the XF forum for a threat called "interesting find during water pump change". Everything will be same for your XJ.
#42
#43
So Cwalkey was right then there is only one hose.
By the way, in Hong Kong we never had XF 5.0 sc non XFR version, we only had 5.0 NA and XFR.
#44
Received 3,266 Likes
Yes, according to JLR the SC fluid is "for life" and there is no scheduled renewal mileage, but as I have commented elsewhere it seems to be the same idea as the auto trans fluid in the ZF 6 and 8 speeds - "for life" according to JLR but should be changed every 60,000 miles according to ZF.
I suspect JLRs definition of "for life" means "approximately 10 years" as very few owners of a modern Jag keep it for more than 10 years.
#45
There are a few reports on this forum and elsewhere of owners who have renewed the SC oil/fluid/lube (mainly on the 4.2 and 5.0 V8s) and most reported the same thing - the old oil came out looking dark, burnt and dirty and the SC was much quieter and smoother after the change.
#46
EmmanuelTam The front snout of the supercharger has two grease filled bearings that overtime wear out, that is when you rebuild the snout. The isolator that is on the link is the same solid type that i purchased from Ebay The plastic connector goes between the water pump and the oil cooler the pump has to come off to replace the platic peace.There is an rubber coolant hose that runs under the supercharger to the throttle body it is clipped to the supercharger bottom.
Now I am pulling the trigger and putting all the parts into my shopping basket for checkout.
Cwalkey may I ask if you have a pic of the highlighted hose or the part number of it? Is this the hose you mentioned AJ812140 (which is now superceded by AJ813614)?Or this is another item that I need to put into my shopping basket as well?
#48
Otherwise by looking at the pic I definitely would have no idea it is sitting between the supercharger and the engine.
It is now superseded by #AJ813614
Also, do you know any other hoses are worth replacing during the engine out procedure? Because it would be a good time to replace everything that needed to be replace at one go instead of having to drop the engine once again for one or two hoses.
#49
meanweather
01-29-2020 06:13 AM
Rocky15
02-01-2016 05:53 AM
