XJ ( X351 ) 2009 - 2019
Have We Decided on mods??
Old 05-07-2019, 12:31 PM
RoketRdr's Avatar
Originally Posted by XJ-SS
Mercedes used a similar cooling system on their 55k engines. When I split mine and upgraded the SC pump, I only saw temp drops of less than 10* F compared to stock. They would both heat soak after 1 WOT blast. In FL heat anyway.
I think meth is the best solution.
Unfortunately all positive displacement supercharged engines heat soak. All the cooling system modding just prolongs it a bit. Water/meth, nitrous or chiller systems are the only way to really get control of it. I agree that meth is the best solution for DI engines not just for the added power and temp drops but also for the benefit of keeping the intake runners and valves clean.
Has anyone found the limits of these transmission yet? Making the power is the easy part. Getting the transmission to hold it and put it to the ground without breaking is the weak link.
Old 05-07-2019, 12:58 PM
XJ-SS's Avatar
What is the limit of the injectors?
Old 05-07-2019, 02:16 PM
XJsss's Avatar
Not sure of the HP, I think it is in the 650hp range, but I know the max torque is 516 foot pounds.
Old 05-07-2019, 02:28 PM
RoketRdr's Avatar
Good question as well as what is the limit of the stock coils? This is my first Jag project so I'm researching to learn where the limits are that will hinder upgrades. I know in the Ford, Dodge, GM communities that the stock injectors and coils are typically good to around 900HP. Given that a lot of the parts on this engine are from Ford I'm "assuming" this engine is capable of the same. During R&D it was tested to 850HP so I expect that the stock injectors and coils are good to that point.
Old 05-07-2019, 02:30 PM
RoketRdr's Avatar
There are a couple of vendors out there building the 8HP70's and 90's for the Dodge community to handle 1000+HP. I suspect I'll end up giving them a call in the future.
Old 05-07-2019, 06:50 PM
NvmyJag's Avatar
Anyone have any before and after dyno numbers to compare to say if any of these mods actually lived up to their claims?
Old 05-07-2019, 10:24 PM
Nedoerr's Avatar
The injectors on my 2010 XJL s/c are Bosch part # 0 261 500 298. They are rated:
1050cc/min = 718g/min = 66lb/hr @ 100bar
Dont know if that helps.
  #28
Old 05-07-2019, 11:06 PM
RoketRdr's Avatar
YES!! That is extremely helpful!!! Thank you.
paulmj
59
02-15-2021 09:18 AM
Uncle Fishbits
04-26-2019 05:40 PM
carmat731
12-13-2010 09:26 PM
ohnoesaz
03-02-2007 01:12 PM
Quick Reply: Have We Decided on mods??
