Hazard Switch stays lit????????
Received 3,910 Likes
Blake04VDP, looking at the diagrams, it would appear that your hazzard switch is bad. It has its own little "module" attached to the switch. It appears to be overly complicated for what I would expect as they have the CAN bus running through the switch. I would start there and then see what you have then. If it isn't that, then you are looking at a problem in the fuse box which will require replacing the whole fuse box.
What is your definition of long time? They do stay on until vehicle goes to sleep which can take awhile.
John 70
07-22-2013 07:43 AM
