Headlights will not turn off
My 2008 XJR has an "Auto" setting for the headlights. When I use it, the lights do not turn off when I turn off the ignition. The "headlight on" beeper sounds and I have to turn the switch to "off". This has just started. I have owned the car three years with no such problem previously.
You'll probably have more luck in the X350/X358 forum.
Certainly in the X100 XKs there have been problems with soldered joints going bad in the indicator stalk, might be worth a search.
I hope you find a solution without causing your wallet too much grief!
This might point you in the right direction (it's slightly different, but in the area I was thinking of):
https://www.jaguarforums.com/forum/x...riving-125570/
I've taken video of all of this and will be dropping it off next month.
