Heated/cooled seat module location
ddanielcigars (10-10-2022)
Hi wombat.
thanks for the reply, I literally searched everywhere under both seats but didn't raise the carpet. I have no issues removing the seat to get to it but just want to know what position it is before i start and i cannot locate a drawing anywhere for love nor money.
also how do you mean replace with f-150?
Timothy Geyer (09-17-2023)
Shinxter,
The more I think about it, it's located under the carpet, directly under the seat. You don't need to fully remove the seat, just undo the 4 bolts and tip the seat forwards. (Work from the backseat area with the front seat motored forwards). You can then follow the wiring harness back to where it enters a cut flap in the carpet.
The module is a Ford part that is used in numerous Ford vehicles including the F-150 series...Lots cheaper than a JLR part.
The modules under each seat are identical.You can test a module by swapping it between the seats and check for functionality.
wombat
(Still not 100% sure that it isn't mounted to the seat base!!!!!)
wombat
The following 2 users liked this post by wombat:
bgpenguin21 (03-27-2023),
Sphinxter (10-01-2022)
I can only find a "Climate Seat Module" in an XF? Looks like it's more towards the center console too.
Maybe behind the front screen AC controls?
It's item 16 in the diagram below. Not much help I am afraid for your XJ?
In my XJ manual I have this wonderfully descriptive sentence?
"Locate climate seat module, (refer to Electrical Information - Electrical Reference Library, contained in TOPIx) for
guidance on how to gain access to the connector(s)"
FastEddie02043 (11-19-2022)
hi, where did you get this diagram from, I'm having trouble locating my heated and cooled seat module in my 2014 xf, it is not under the floor or in either the passenger side or drivers side seat and it is doing my head in , looks like it is behind the glove on this, presuming this is right hand drive that is. any help would be appreciated
cheers
john
cheers
john
Hi wombat.
Did you find it?
Thank you.
Tim
Hi Tim. I found one under the carpet by front passengers feet and I am certain that unit controls both front seats but I am being told otherwise, I've had all seats out and carpet up and there is defo only 1 at the front. The rear is under the bench seat though.
what troubles are you having?
[QUOTE=Timothy Geyer;2679329]Hi Sphinxter,
I found it. Mine is a right hand drive. The heater module is under the carpet under the front passenger seat. A kind chap named Vic Tor on Facebook gave me the tip. See pictures attached.
Regards,
Tim
Heated seat module location. Under the carpet under the front passenger seat.
Regards,
Tim
