Heated mirror / Fuses
poketastic (01-22-2018)
poketastic, a simple check that you can do is the side that is not heating up, try moving the mirror. If the mirror moves, then you have power to the heater as it shares a common fuse with the computer that controls the door.
If you want to check the fuses, it would be fuse F32 (driver's side) and F30 (passenger side). Both of these fuses should be a 25 amp fuse.
Smudge67
12-16-2017 09:52 AM
harold72
11-08-2017 09:58 PM
04X-Type3.0
12-26-2012 03:48 PM
Rocafella117
09-06-2010 04:10 AM
