Heated outside morrors
There is no symbol on mine (which are heated), but US-spec mirrors are very different to UK ones as you seem to have curves and writing on them. They should work as Hank describes.
If you want to check yours just pull the look to see if there are two wires attached to the rear of the glass with metal tab crimps. Push the glass in towards the car until fully adjusted inwards and look behind the exposed outer edge. You don't need to remove the glass to see as they are along the outer edge (maybe 1" in).
Smudge67
12-16-2017 09:52 AM
04X-Type3.0
12-26-2012 03:48 PM
