Heater control module
The following 2 users liked this post by hafren:
alanhodges (10-19-2017),
XJsss (10-19-2017)
Alan
The diagram is from the electrical wiring diagrams (EWDs) on https://topix.jaguar.jlrext.com/topix/user/loginForm. Anyone can register there, but there is a fee to access the information which differs based on the models and length of access you require.
What is it you need to do with your module? Are you replacing it? I can grab the workshop instructions for removing the module later if needed.
alanhodges (10-20-2017)
I'm having a problem with the passenger side front and the same side behind. There's no heat and the blower doesn't seem to blow air out either. Driver and seat behind, all work fine. I've look around for help on the net, no joy. I'm at a loss, the local dealership want's 1600,for doing the fix. I can't afford to pay that, so it's up to seek and destroy lol
Any help diagrams or components of the heater/cooling system would help me out.
Thanks for your help so far.
Alan
1 Post
cold air on passenger side
Hi Alan, I see that this is an old post but I was wondering if you have fixed this problem as I have the same on my 2011 X351?
If I do HARD reset by disconnecting the Battery positive for 30 mins then the Climate Control works perfectly for a few days but then reverts to Cold Air on Nearside of car.
Would love to know how you got on.
Thanks in advance.
Phil
Thanks in advance.
Phil
I believe I have the same problem.
B11ed-87 electric heater control module- permanent error. Is the code above the part number for the piece?
And…. Has anything to do with fan blowing hot and cold air at the same time on the passenger side for a left drive car? Driver-left side is cold ok.
The passenger side I think it uses the electrical heater to make cold air from the cooling system hot again.
Help?
Help?
The electric heater is last device on LIN-bus controlling the left side air circulation flaps. Failure can mess up the comminication and left side flaps enter on uncontrolled state
Happens on my friends XJ and after we changed the control printed circuit board of the heater on site, the control of the flaps returns. (bit tricky to change it, but still less work than change whole heater. (LHD driven vehicle)
After it the weather warms up… will give it a try….myself.
Guys…. X351 is drive by wire or mechanical? Could be a problem with steering wheels sensor?
