Help ! Battery Dead ! Car Locked ! How do I access the battery?
hello,
I am sure you guys are thinking why not call the dealer, well I am in Bangladesh with no Jaguar dealer anywhere within a 3000 mile radius. Anyway I need to gain access to the trunk to gain access to the battery .How to access it ? The car from day one had the issue saying CHARGING FAULT. But it drove fine and the battery guys said its getting OK voltage and no issue. So how do I get the key fob to unlock the doors ? Any solutions ?
Thanks in Advance
Thanks in Advance
I assume because you have posted into the X351 forum that your car is one of those, i.e the current on-sale model of the XJ saloon constructed of aluminium.
Normally on Jaguars the boot can also be opened with the key but you first have to find the lock entry point. This is normally somewhere at the rear of the boot lid on the number plate light plinth, but that is my car which is the previous model of XJ saloon. If your car has this facility have a good look round the boot lid. On my car it is on the underside of the number plate light plinth, so hard to see.
Hope this helps you
Hope this helps you
Open your key fob by depressing the button on the side. Inside the fob is a blade like key you are supposed to use to pry off the driver door lock cover, then insert the key into the key slot, turn it toward the rear of the car to open the car door.
If I recall correctly, you then have to open the hood to get to the battery charging posts that will allow you to power the cars electrical system enough to open the truck to get to the battery. Good luck with your predicament.
Ken Dreger (06-14-2021)
Received 6,320 Likes
Hope this helps you
Hope this helps you
1. open driver door with key-fob key
2. open hood with release lever
3. remove the cover from the fuze box on the passenger side of the engine compartment
4. attach jumper cables to the charge point in the fuze box - DO NOT ATTEMPT TO START THE CAR!!!
5. go back in the car and hit the trunk release button
6. remove the jumper cables and re-attach to the battery/charge points in the trunk to re-charge the battery
All this is detailed in the manual but the first time it happened to me, I was at a store and the manual was in the trunk! Thank god for smartphones and mobile internet!
The following 3 users liked this post by another_geek:
I love my 2011 XJ, but I have to agree. I have to wonder, which is more complicated and time consuming:
1. A 2011 XJ owner recharging a dead battery from a lockout-start like our unfortunate friend in Bangladesh, or
2. US Air Force officers performing a missle-launch sequence?
MISSLE-launch sequence
~That's funny~
Bill--------------------------->
The following 2 users liked this post by aceeg:
Jesse James (05-02-2013),
It's not a big deal--just a little plastic cover so you don't have to look at a keyhole. Personally, I think it's a nice touch since chances are you'll never need to take it off.
Thank you all so much, well got the door open with the key fob, replaced the battery with new, but it still says CHARGING SYSTEM FAULT, but the battery guys are saying it is getting full charge. Any other 2011 XJ 3.0 LWB Portfolio has this issue ? again thank you so much
The x351 does not have a mechanical key lock to open the trunk as in previous cars. It is electronic only. Only the driver-side door has a mechanical lock for emergencies. Gostratusgrey is correct in that the sequence is
I hooked up the jump leads to the charge tab in the under-hood fuse-box (and the ground on the chassis). The car lights came back on and then...I made the mistake of ATTEMPTING TO START THE CAR!!! Pooof, all dead again and the trunk/glove box still closed!
Luckily no long term damage...I didn't even blow that 100 amp fuse on the charge tab. I came back to the car the next day (after reading your post) and all worked well. Got into the trunk, changed the battery and all is well!
Thanks again!
Car shut down and engine smoking. HELP.
My car shut down everything.
All lights were flashing inside, smoke coming from engine.
All power lost. Put oil into engine.
Opened bonnet and put charge through to open boot.
Key wouldn't open boot. Internal boot button wouldn't open boot.
Lights in car coming up with all warnings.
Thinks all car doors and boot are open.
Any advice to get boot open?
2011 XJ L 3L Diesel. No special access near number plate to open boot.
Please advise.
Thanks.
BKSinAZ
04-20-2015 04:48 PM
