XJ ( X351 ) 2009 - 2019
Help! "D" Flashes and car acts like it's in neutral...
Old 01-26-2019 | 12:40 AM
lospice1's Avatar
Default Help! "D" Flashes and car acts like it's in neutral...
My 2012 XJL Supercharged is acting funny. It was driving fine until I slowed down to go over a speed bump. Then the car acts like it's in neutral and "D" flashes on the dash great indicator. I turned the gear selector to neutral and then back to drive and it drive normally but I did notice some slight jerking when getting on the throttle at low speed.
Any ideas what could be the problem? It's still under extended warranty, so I'll probably bring it to the dealership unless there is a DIY fix.
thanks,
Will
Old 02-04-2019 | 03:45 PM
Hank Scorpio's Avatar
Thats really odd. Did it do it again since then? I could have been a weird software glitch or something. I havent heard of many, if any at all, issues with the ZF boxes.
Old 02-19-2019 | 11:35 PM
1Willy1's Avatar
Id try to get the tranny "reflashed" first and see if that solves it
On a side note, im close to buying a 2012 5.0 supercharged xjl and im wondering if its possible for me to get a proper warrantee on it through jaguar?
The car is being sold by a ford dealer, they say they offer some warrantees but id rather get it straight from jag if possible
How did you manage to get your warrantee?
Old 02-20-2019 | 10:43 AM
I can just give you my input/experience. When i got my 2012, it still had the Jaguar CPO warranty. we tried to negotiate extending that CPO, but they just flat out said JLR would not let them extend CPOs once you were beyond certain terms. They gave me a third party one instead that supposedly matched the CPO, but i have not had to use it yet to report back how good it was.
that being said, unless the car fits the criteria for a CPO, i dont think you can get an ext warranty from Jag. youd have to get one of the 3rd party ones like i did.
Old 02-20-2019 | 11:39 AM
clubairth1's Avatar
It might need a replacement shifter too?
When the rotary shifter was first introduced there were a number of reported failures. But as the years went by we stopped hearing about this so I think Jaguar got it fixed.
But if you can post back with the codes they found and what the final solution was. Assuming you DO get it fixed at some point!
Old 04-29-2024 | 03:22 PM
Shahrukh's Avatar
thanks,
Will
same problem in me car
Debra Glass
10-13-2017 06:42 AM
9under1roof
08-15-2017 08:32 PM
Ronnyrhodes
08-14-2016 02:43 PM
Burdedw
09-12-2015 11:39 AM
Darrenmb
11-15-2014 02:42 PM
Quick Reply: Help! "D" Flashes and car acts like it's in neutral...
