I am stuck on remove the front seat backing. I started with the lower clips but the top two are stuck. I am suprised that they have broke ln yet. Thats how much force i have put on them. I know i am missing something.
After unhooking the two bottom push pins the top connectors are hooks. So you need to push UP on the seat back to unhook these. You are destroying them by pulling out on the seat back like how you released the two bottom connections. You can see where the plastic hook is bent.
Hopefully the hooks are not too damaged because the seat back might not be attached very tight after you reinstall it. You also can break the hooks completely off which ruins the seat back.
To reinstall first put the hooks thru the plastic loops on the top of the seats backside. Then slide the seat back down until the two bottom push pins align with their holes. Push the seat back into place.
