Help pls.......
With a 2012 (originally offered with a rear camera only):
1) Add the camera module to the rear bumper cover.
2) Add missing wiring. You may find it already there and connected to a blank plug, or it may be totally missing, depending on build date and market. Harnesses involved are the rear bumper harness which enters the car through the rear of the boot/trunk well, the main cabin harness which takes the video coax from the boot harness to the side of the transmission tunnel under the gear selector, and the touch screen (centre console) link harness that takes the coax from there to the rear of the touch screen itself.
3) Edit the car's CCF data to enable the rear view camera option. This will require SDD and some experience to program.
If you are unable to do this yourself then Cambo (on these forums) may be able to put you in touch with someone locally who can do this.
Welcome to the forum Mahmoud,
