Help replacing right side outside rear view mirror
hi All,
it happened...........I just barely hooked the right wing mirror on the garage door trim while backing out. The only thing apparently broken is the bezel around the housing which is part of the chassis that has the motors, not available separately. everything else is good and all functions work. Where in the US is a good used mirror supplier, what should I expect to pay and how do I get to the mounting fasteners? This is a 2011 XJL supersport.
Regards,
donm
Regards,
donm
You've posted in the wrong sub-forum. This one is for the X350 XJ, 2003-9
You should post in this sub-forum ... https://www.jaguarforums.com/forum/xj-x351-53/
These appear to be internet friendly Jaguar recyclers. A quick search for Jaguar recyclers turned them up. Also keep your eye on Ebay.
XJ - XJ L: Jaguar Used Parts, Auto Body Supplies, Salvage Car Wrecking Junk Yard
Auto Parts Inventory Search | Elite Auto Parts
