How do I control rear AC only?
When I set the unit to rear and turn on the rear a/c to full blast its tied to the front - meaning I cant get the front off and the rear on independently - I click on rear (the rear is lit) turn up the AC and then the front blower gets loud and the front and rear start blowing - very frustrating - any help?
Good point. I will play with mine a bit. I'll let you know. I don't think my front blows in the case you described. I will double check and let you know. May be something isn't working correctly in yours. I will turn up the back and let you know if the front still blows.
Calling it a real 4 zone would be simply misleading and false if that is the case. Back to my 2002 X5 and my 2008 CLS63 the 4 zone is a real 4 zone with seaparate fans for front and back.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
