How to Fix Illuminated Scuff / Tread plates: step-by-step
Backstory: My rear, LH illuminated scuff / tread plate stopped working. Started to bug me. SWB replacements are nearly impossible to find and/or are stupidly expensive.
Technology: Electroluminescent (EL) panels are reasonable robust but the EL Driver / Inverters are not. These drivers convert the cars' 12Vdc to approx. 80ac to drive the panel.
So . . . thought I would dive in and try to replace the driver / inverter. Come along for the journey.
The following 11 users liked this post by Maxpower:
dmchao (07-23-2024),
Ken Dreger (08-10-2024),
kroache (09-17-2021),
Na5h (09-17-2021),
rothwell (08-09-2021),
and 6 others liked this post.
Bumping this thread from the grave because the OP @Maxpower seems to still be active on the forums. What is the part number of the 12v inverter/driver module and where did you obtain it? Trying to attempt this repair not but I can't find an inverter module that has the dimensions that fit.
Our treadplates were manufactured by "GSM Industrial Graphics" which is still in business. I have reached out to them, but as they were acquired by another business and this was over a decade ago, I doubt they'll be much help.
Post some pics of your repair to keep the community thriving!
The following 3 users liked this post by Maxpower:
You can purchase them from here: https://elpanelandtape.co.uk/product/silent-100cm2/
Maxpower (06-24-2024)
Update- I fixed my treadplate illumination today on my 2013 XJL Supersport using the part Maxpower posted above. I had quite a time as I accidentally ripped two of the foil tape connections. Some very delicate work with the soldering iron put me back on track. The 12v power wire coming from the kick panel on my car was yellow/violet as also indicated on the wiring diagram, most years of X351 should be similar.
Stuart S (07-20-2024)
wombat (07-20-2024)
Hey guys. I have used a soldering iron before but I was wondering if there was a video or a more detailed version of this? I looked at the list and wasn’t sure what power supply to order. And the foil tape, I couldn’t tell which line it was referring to.
I would like to fix it myself but trying to prepare before I get in there and destroy things.
The 'foil tape' is the two connections label 'AC Connections' in the first image.
Post pics of your repair!
My foil tape ripped right where the large white plastic bracket (that has the clips that actually attach the treadplate to the car) is adhered to the plate itself. To access a fresh length of foil tape on which to make a new connection, I had to split the plastic housing by prying it away from the plate using brute force. I soldered new connections to the actual electroluminescent tape (carefully to avoid burn through) and re-adhered the treadplate to the mounting bracket using new double sided tape after cleaning it up.
The vendor that sells the EL driver used for this repair also sells lengths of electroluminescent tape. I suppose if you completely buggered the job you could just adhere new EL tape underneath the plate. I'm sure there is a way that cars without this option could create their own illuminated treadplates or kick panels using this tape. Does anyone know if their XJ that was NOT optioned with illuminated tread plates still has the wiring harness underneath?
RaceDiagnostics
03-17-2019 11:07 AM
BlownBrit
10-03-2016 03:37 PM
