How to get the car off the Valet Mode without the Master Key?
First thing to do is replace the battery in your keyfob. If that doesn't solve your problem, then post your inquiry in the proper XJ forum. This is the X351 Forum for the current model 2010-up XJ. You should post it here: https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
Received 3,910 Likes
Chef Santiago, odds are, if replacing the battery in the keyfob does not fix it for you, you will be force to take it to the dealership to have them reset it. The one thing that I would try is to access the power to the radio. Pull both the battery power and the switchable power (will require pulling 2 different fuses). Leave them out for say 5 minutes and then put them back in. see if that resets the valet mode. Since your car is in the US, you should not have to enter a code to get the radio back on.
Chef Santiago
04-27-2019 09:16 PM
Collector1
02-16-2015 01:19 AM
rlwpromo
12-29-2012 06:43 PM
