How to remove the alternator on my x351 3.0d
The following 2 users liked this post by Vasara:
Drfrankenfish (02-23-2022),
ralphwg (03-06-2022)
thank you-is it the jag workshop manual? I have that and it tells me to remove the turbo bypass and undo an engine mount and Jack the engine up from the sump!! How daft for a serviceable part but if that’s the only way then there it is-I initially just wanted to replace the clutch pulley but it had no cover on and I haven’t got enough leverage to undo the nut and I’m also unsure if it undos conventionally like anti clock then the pulley is threaded-it’s sending me bonkers 😜 thank you though I’ll check if it’s the one I have 🙏
Yep, thats the one. I heard that it would be possible to remove from top on XJ, by removing airpipes etc on front of engine, but in the end it is more work than underneath. Engine need to be tilted only 10-20mm from alternator side. (leave nut loose on the end of threats..) Use wooden blank under sump.
I don´t know how the pulley are mounted on Denso alternator used on 3.0D. It is not mentioned on manual... as usual these workshop manuals are only for dealer services who only replace parts, not repair them...
