How to remove rear seat in XJ (X351) ?
Does anyone know how to remove the rear seat in an XJ ?
Im fitting a dashcam (with front and rear cameras) and it seems the easiest way to get power (i need a constant and a switched feed) is from the fuses in the central fuse box behind the rear seat arm rest. Only problem is how to get the wires from the door pillar to this point behind the seat? If i could remove the seat base i could run the wires underneath and into the fusebox, but i can't figure out how the seat is removed - It seems like the seat might just be clipped in place at the front edge, but I don't want to break anything trying to get it apart!
Anyone here have any experience of this?
Rich
Rich
The following 2 users liked this post by XJsss:
dfmaf2004 (02-10-2021),
mikebaker3 (02-09-2021)
Pulling the strap is the only way I’m aware to do it. It should help to throw your weight into the seat back while pulling. You might also try pulling the strap with more of a quick jerk instead of being controlled with the pull. Alternatively you could try to undo the problematic side first, see if that helps.
Hope you’re able to solve it.
I just did it today in my XJ supersport just finished a few minutes ago
I had a noise -rackle coming from the subwoofers at the rear I have the Bowers Wilkins sound system, and to see what is that rackle that was horrible, I start removing the seats, the lower part it is easy to remove, just find the clips with the finger and unclip them, disconnect the few electrical from the seat ( I have ventilated etc) the upper part of the seat it is very easy, just push the 2 strings below the seat and it release it and il goes down, very easy. (push in one go like PAM ( I understand myself:- ) then the problems start, it is absolutely not easy to remove the rear shelf, there is 2 screws a bit hidden one in each side, and you need to remove the side pillars too, you need a lot of effort and passion to remove the rear shell it self,
after succeeding and doing hours of Yoga in the car, I see the problem, the screws that hold the subwoofers, they were completely loose. That was the rackle noise.
To put all back was quite easy, and now the sound is great again.
some pictures
some pictures
Try pulling the strap with one hand and then at the same time press down hard at the strap on the point where it is coming from under the back rest.
That way you have much more down force on the strap and not just pulling the bottom of the seat forward.
The strap is attached to a lock tab at the top of the rear of the backrest which unlocks with downward force.
Hi,
I was tried to removal passenger's rear seat for install IPMB. However I didn't understand how to do it. I read the manual several times. Most of manual, post said that the bottom can be removed using this lever. My Jag didn't exist a lever there. (Or I didn't find it) What am I missing? Anybody have good ideas?
It is XJL(X351) 2017. Thanks!
Hi,
