XJ ( X351 ) 2009 - 2019
Intercooler
Old 01-01-2024 | 08:02 AM
RegMeister's Avatar
Default Intercooler
Happy New Year. I am a new member and would really appreciate some help from the existing members.
Jackie is part of my wedding car entourage and recently there was a pop from under the bonnet. The restricted performance red warning displayed on the screen and what appear a limp mode kicked in. I got home, which was 10 miles away and started the Google diagnosis.
The suggestion was the intercooler and it seems that the plastic casing just below the exit pipe had split. By wedging a piece of wood between the housing and the bulkhead I could reduce the escape of air which was reflected in the running. I am going to attempt a fix with some heavy duty sealant.....
My question is: how long should the replacement of said item take.
The garage said 5 hours.
Does anyone have a video or link to the job to replace the intercooler. I appreciate it means removing the bumper.
Sealing the split would be ideal rather than the cost of a new intercooler and replacement.... Quoted £700 so far.
Thanks in
The split is around the rear flat chamber which is about 6 x 3 inches
advance for any help
Old 01-02-2024 | 08:23 AM
clubairth1's Avatar
Can you tell us what car and engine you have?
I do know Jaguars but that picture does not help to identify what you have?
Old 01-02-2024 | 08:45 AM
RegMeister's Avatar
Hi,
it's a 2010 Portfolio 3.0 V6 diesel
Old 01-02-2024 | 08:48 AM
RegMeister's Avatar
The area that has split and been enlarged is on the right hand side of the image
Old 01-02-2024 | 09:21 AM
clubairth1's Avatar
Thanks for the added car details. We are weak on Diesels on this forum since it's mainly US guys and the US never got any Jaguar Diesels.
BUT the UK forum is chock a block full of Diesels and I am sure they have some threads on your car and it's problems.
UK Jaguar Forum
I replaced the IC on my 2014 XJR with a larger all Aluminum version and thought I might be able to help you as I still have my stock IC. But they are completely different as I suspected. I don't know if on the Diesels is this a failure prone part or not? I would suggest getting a used part as IC don't wear out BUT they are plastic so age may affect this too?
Old 01-02-2024 | 09:23 AM
RegMeister's Avatar
That's very kind. How foolish of me. Wrong country!!!!
Old 01-02-2024 | 10:05 AM
clubairth1's Avatar
Hey we are all part of the Jaguar family in the end!
Julia700
04-17-2023 10:22 AM
Tour82
07-15-2021 12:42 PM
peterg001
03-11-2019 04:25 PM
stevevaus
03-10-2011 04:09 PM
Quick Reply: Intercooler
