XJ ( X351 ) 2009 - 2019
Interest in helical gear differential development
Old 01-10-2023 | 05:43 PM
HermanWiegman's Avatar
Default Interest in helical gear differential development
Jump over to the F-Type channel to enter your level of interest in having a helical gear differential designed and built.
The Back Story: I am trying to develop a limited slip differential solution for the following Jaguars with DANA 44 AdvanTEK rear axles.
  • F-Type, F-Pace, XF
  • possibly some XE and XJ models
The solution would be based on a helical gear differential carrier, which is also called a Torsen® or TrueTrac®. This type of LSD has the following advantages over traditional friction plate types.
  • Maintenance free as there are no clutches or springs
  • Quiet operation with no clicking or ratcheting mechanisms
  • Both forward and reverse torque transfer capability
  • Instant torque transfer
I also need to learn a bit more about the XE and XJ rear axles. If you have an old one or access to a parts axle, please contact me. There are a few key dimensions that will instantly tell us if it is compatible.
Thanks, Herman
KiwiJon (01-11-2023)
HermanWiegman
XE ( X760 )
08-22-2024 09:03 AM
HermanWiegman
02-18-2023 04:21 PM
HermanWiegman
F-Pace (X761) / C-X17
01-10-2023 05:42 PM
HermanWiegman
XF (X260)
01-10-2023 05:41 PM
Quick Reply: Interest in helical gear differential development
