Interior Lighting bulbs LED
Hello All,
Today, I changed all of the interior lights to LEDs and also my license plate light bulbs.
My question is how do I remove the front housing where the sunroof switch etc is? I tried but didn't want to break the housing and I figured someone must have removed it before and knows how.
Thanks!
Thanks!
Received 3,905 Likes
Get in between the plastic housing and the fabric of the ceiling with a flat blade item (popsicle stick, taped up flat blade screw driver, etc). Once under, pull straight down about 1/2" or a little more. You will hear it pop as the clips let go. Then you can work your way around to the front and undo the 2 clips there.
Worst case, wait till you get to my place and we can do them then.
JagGuyMD (11-25-2015)
philwarner
12-02-2015 01:25 PM
mkprator
11-30-2015 06:58 PM
