interior lights
Got my jag back with software upgrade and just noticed that the interior lights do not go on when entering and exiting car.
Is there a switch that might have been turned that keeps the interior lights out?
I can put them on manually by touching them, overhead by mirror but they will not go on with entry and exit.
I had the same issue. I found out (buried in the handbook) that there is a way to switch from 'lights auto on when you open the door', to ....not. You touch and hold the center light (next to the rear view mirror) and it will switch it back to auto mode. The right hand dial in the dash will confirm. I can't remember if the ignition needs to be on or not (I think not.....in spite of what it says in the handbook)
Hope it works.
Nigel
Hope it works.
Nigel
rsa760041
23
09-25-2015 01:33 PM
