View Poll Results: This survey is to identify the category of the people using K&N filters and the ones
XK8 With K&N Filter Installed
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2-r.gif)
![](https://www.jaguarforums.com/forum/clear.gif)
20.69%
XJ With K&N Filter Installed
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3-r.gif)
17
29.31%
S-Type With K&N Filter Installed
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar4-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar4.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar4-r.gif)
17
29.31%
XK8 With K&N Filter Removed For A Reason
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar5-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar5.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar5-r.gif)
1.72%
XJ With K&N Filter Removed For A Reason
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar6-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar6.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar6-r.gif)
13.79%
S-Type With K&N Filter Removed For A Reason
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar1-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar1.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar1-r.gif)
5.17%
Voters: 58. You may not vote on this poll
K&N filter
#41
Jagmaster, I'm not sure about the cold air intake you installed on your XJ, but many of the "cold air intakes" that I've seen are nothing more than a cone filter in the engine bay. On my XK8 the air is sucked in from under the front right fender. That air is going to be much colder than the air directly behind the radiator in in the engine compartment.
I'm not saying that your cold air intake doesn't improve performance, I don't know what yours looks like. I'm just saying that the cone filters in the engine bay that are sold as "cold air intakes" are actually sucking in hot engine bay air.
Here's an example of a "cold air intake" that I just found by googling. This thing is virtually worthless. It would work much better if it had a shroud around it and pipe going down into the wheel well.
![](http://img292.imageshack.us/img292/7038/intake1gd8.jpg)
#42
Excellent!! You are spot on Maybe_XJ, spot on! ANYTHING that alters the original design air flow will impact fuel mapping. I know many, many folks will argue with me, but I just can't tell you how many cars I have "repaired" simply by removing a K&N. Sometimes the effect is subtle, sometimes massive. The best example I can cite is our Rover guys. One of their air boxes has a baffle that can get out of place and make a small obstruction in the incoming air. Kind of like laying a pencil across an open vacuum cleaner hose. That minor obstruction/restriction causes a full size Range Rover to fall on its face during acceleration, even sets rich fueling faults. It took a very qualified tech three days to pin that down.
Sorry K&N lovers, leave 'em to the carburetors!
Cheers,
Cheers,
I can attest to your comment. K&N filters ran RUIN on my XJR. Leave the paper filters that Jaguar designed the car with on there.
My god are Jaguar super sensitive.
#44
You guys are all sweating over just one angle - the MAF. Keep in mind that there are other sensors like the IAT (Intake temperature sensor) and this one can give different readings if the flow of air is higher than expected (something K&N filters will give - more airflow)..
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Jagmaster was making a lot of sense along these lines.
So I stick with the ORIGINAL engineer-chosen filter for the car I drive. Having said that, if I'd go with lots of other modifications, than all bets are off and I would need a very good NERD to tinker with the ECU software. Not going to happen. The ECU software is one of the most guarded secrets of each manufacturer, and the people that actually know all the ins and outs of it are already working at their respective car manufacturers.)
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
Since the OEM only buys one filter/car (two for XFR and select others) and beyond that it is the operator's cost and responsibility, you get paper. They are the cheapest, one-time solution. You would see far more variety in the types of filters chosen by the OEM's if it were something they were responsible for replacing/maintaining. Over the life of the car, washable, reuseable filters are clearly the more economic solution: K&N for 3.0L S-type? $40. Paper from Jag Dealer? $20 Rock Auto? $3.50 - $15. Increased "Moan" under WOT with K&N? Priceless. So depending where you would buy your paper, the break-even point financially is 2-5 filter changes for that model. Others may be different, but I have an eclectic mix of veh. and they all fit that range.
Just as Maybe_XJ prefers the engineer-chosen filters supplied by the dealership, because he is focused on the designed-in control system balance, I prefer washable filters for the economic advantage. Previous posters indicated they had removed K&N's due to loss of low-end torque. Wow! I'm thinking my butt-cheeks have a serious lack of sensitivity! Like Jagmaster observed, the only thing I can "feel" a performance impact before/after is the diesel Excursion* with a cold-air intake. Sorry, no 0-60 times from the track to prove it. ALL reusable filters I've used have made a noticeable change in the intake noise under WOT, however...so maybe they "sound stronger!"
In the very end, I think XJRGuy said it best in observing we should all enjoy these fine machines irrespective of how we choose to filter the air they suck in the front, or the rationale for the choice.
___________________________________--
*Didn't acquire for performance, rather a cheaper solution to mount filter and battery than OEM when rebuilding from a front-end impact.
Deja Dilbert Vu: When you experience at work what you read in Dilbert within the last month....
Panthro (07-03-2017)
#45
#46
If you stand outside naked when it's say.... 35F, you will "feel" it's cold. If you hop on a motorcycle naked and go 60mph, you will freeze your a$$ off. The K&N - because of the increase in air flow - WILL INFLUENCE the air temp sensor too, in cold or warm weather. Not just the MAF readings.
I'm done with this discussion - we're all entitled to our opinions and mine is, don't waste money with aftermarket overly-hyped-marketing-engineered products. Jeez might as well buy internet infomercial kits that will make you wealthy in 2 weeks LMAO
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
![Icon Crackup](https://www.jaguarforums.com/forum/images/smilies/icon_crackup.gif)
#47
Sorry... wind chill may have an effect on the way you "feel", but wind doesn't increase the density of the air. The intake air temperature sensor measure the actual temperature of the air. It doesn't measure the wind chill. The temperature affects the density, and that's what the ECU needs to know. Colder air is denser, therefore it contains more oxygen which means it can burn more fuel. If the IAT sensor sent the ECU the wind chill rather than the actual temperature, then the ECU would tell the injectors to inject more fuel and the mixture would be too rich, which would cause gas mileage to decrease.
The K&N does not influence the intake air temperature sensor. If the air flowing past the sensor is 34 degrees, moving the air faster isn't going to make the sensor think it's 30 degrees. If so, then you could freeze water by blowing 34 degree air past it. If you can figure out a way to do that, then you'll be a rich man because it violates several laws of physics.
#48
I think you are mixing the workings of the MAF and the Temp sensor. The Temp sensor sits outside the tube where the airflow sensor is residing, and does not have an internal heat source where wind-chill would have an effect. It is a standard temp sensor.
To make it simple: you have an outside temp sensor which you can monitor on your dashboard, now if you would drive faster, does it get colder outside?
The MAF however actually does react on the wind-chill.
The wire will be heated at a constant rate, and the more air flow (wind-chill), the more it will be cooled, and the more current has to be send thru the wire. The MAF will send out a voltage proportionally to the current it has to put in the wire. Here is a picture:
![](http://i53.tinypic.com/2ia63i1.jpg)
#50
#51
Rubbish....I have run my STR without an air filter for half a day waiting for the K&N to dry with no impact on the MAF sensor (or perfornance for that matter). The problems with K&N filters and MAF sensors relate the the oil that is applied to the filter post-cleaning. When applied too heavily (or not allowed to dry a bit) the oil can deposit on the MAF throwing codes. Some vehicles are obviously more sensitive than others however.
#52
I have installed K&N air filters in every car I have ever owned. Not for any other reason than longer service intervals. In my experience they have all been identical in size and fitting to what they are replacing so the difference between it and the OEM filter is small enough that it's highly unlikely to cause an issues and since I've done 10's of thousands of miles on those vehicles and in most cases seen some improvement in either response or fuel economy as well as the reduce filter changes and no issue with the engine getting hot or change in idle, i think it's fair to say that the K&N is worth it.
HOWEVER. The jag K+N air filter that i got for my 1998 XJ8 is significantly different in depth and fitment to the Jag original. It's much shallower and requires a gasket at the top of the air box for sealing.
So it's pretty clear that the air flow will be quite a bit different than when using the stock filter. I was a bit suspicious of it due to the significant difference but figured it was better for the time being than the filthy old one i had in there - my local jaguar specialist advised me to take it out ASAP as he has personally seen lots of problems with them and the AJ series V8's found in the Jags and Land Rovers.
Just my 2 cents for what it's worth.
#53
#54
As for the "wind chill" effect; it's NOT that... think about an air cooled motorcycle engine, it cannot run at 5,ooo rpm for an hour stationary without melting but, can drive 100,000 miles at speed. Thats because of air flow at speed is transfering the heat from the engine away from it... thats how the MAFS works. Think about it! It measures the heat exchanged as air flows through it.
I've used K&N's for years and they work well and DO FLOW MORE AIR than a paper filter. If the eng./air-flow does not require more air, it won't make more power but IF the filter IS a restricion for that eng. set-up then a K&N WILL make more powere as long as the Air /fuel ratio remains correct... thats what the sensors in our F.I cars do... compesate for different condions I.E temps. Air density, altitude , ect.
I vote "YES" for the K&N's!
#55
#56
Guys,
There is no "straight standard answer" like "good" or "bad" when it comes to that subject. It very much depends on so many factors.
First I completely agree with Jag tech and others that even minor modifications may throw off the right balance the ECU is mapped to provide. Power gain (if any) would be minimal and so not worth the risk or project.
Having that said, there are times and cars where a K&N filter WITH the adjusted intake makes perfect sense. I.e. in my (long retired) Porsche Boxster S.
It worked great, added power, colder air and good sound.
BUT, it was not perfect UNTIL I had the ECU re-mapped. (Chip tuning).
So you see, all has to play together to get the desired results.
In the Porsche the K&N setup alone added only 7hp (dyno), once the ECU was remapped I got it to about +18hp which lead to new headers and exhaust to get it to +28 hp.
In other words, the K&N added 7, the ECU about 11hp and the exhaust about another 10hp to get the +28hp total.
But you get the point, neither of those mods would have accomplished great results as a standalone. Afterall , what does a perfect flow exhaust system help if you can't get perfect flow through the intake. And vice versa.
In other words, if you go the K&N route, be prepared to keep moding along quiet a bit through intake, charger pressure, MAP and ECU mapping all the way to the exhaust system. Otherwise I don't see the benefit, only down sides.
Had to get my 2 cents in
![Icon Stooge](https://www.jaguarforums.com/forum/images/smilies/icon_stooge.gif)
