Key Fob case replacement
I have a 2011 XJ with the old style key fob on which the silicone rubber has detached from the chromed metal. I see that it is possible to buy replacement cases for the later fobs for about £10 but the older ones are not being sold. Aliexpress shows them but a closer look comes up with "no longer available". On searching through the forums I noted that someone said that it is possible to slightly modify the old style mechanism to fit the newer fob cases but I can't find the thread that describes how to do this. Can anyone help? Alternatively, has anyone had any success regluing the rubber to the chrome? My efforts with superglue have not been successful!
I managed to superglue both my older style keys with success about 2 years ago.
Use only good grade clue, not "market" one. In most cases markets only sell "home" grade, even from big brand like Locktite. (industrial providers and also major builders shops sell "proper ones". Be aware: They really sticks)
The prhase "less is more" have to keep in mind when working with superclue. The parts have to be spotless and all grease have to be removed from surfaces. I used toothpick to add thin layer on sides and line in the midlle. Positioned the rubber on place and secured with tape over night. Have been holding well since.
Found it. https://www.jaguarforums.com/forum/x...remote-219765/ OP not active since 2019, so this was buried.
FWIW, if you don't have a metal emergency key, get one cut at a locksmith that specializes in automotive. Our emergency key is the same as used in Ford cars. The locksmith can look up the cut pattern from your VIN. This new key probably won't fit in the secret compartment of the new (or old) fob case, but as a neophobe, I like the comfort of a mechanical way to enter the car, should these newfangled electrons go awry.
A771CUS (01-30-2024)
"...then pop the inside sealed layer up using a small flat blade or butter knife."
Picture under that text shows parts separed.
A771CUS (01-31-2024)
Thank You, yes, it just needed rather more brute force than I wanted to apply. Done it now. I don't know what the small square is that is on the back of the board where the cut needs to be made but I see that the corner of it was cut off in the photo showing the board in the new case so presumably it is OK to cut through it.
karenh
09-03-2020 03:59 PM
