Leaking coolant (I know the location)
Hi,
I've a 2011 XJ 3.0D, that recently started leaking coolant.
In the picture below its leaking from the plastic part circled (not the pipe)
Anyone know what it is?
Tried to make and appointment with a mechanic buts its going to be the end of next week before he takes a look.
Thanks in advance
Thanks in advance
I don’t have the 3.0d (I have the 5L petrol), but it looks like the coolant expansion tank return hose. On mine, the connector on the hose started leaking. I would guess yours is also a leak at the connection. A new hose will have new connectors on it and should fix the problem. Again, that’s assuming a similar problem despite dissimilar engines. Apologies in advance if this does not pertain to your situation.
doriel
02-01-2022 01:58 AM
AC0FC
03-16-2017 09:36 AM
hlgeorge
05-05-2010 08:29 PM
