XJ ( X351 ) 2009 - 2019
List of known XJ problems and cost to repair
Old 09-03-2020 | 11:18 AM
drake1980's Avatar
Default List of known XJ problems and cost to repair
Trying to put together a list of known XJ (X351) problems and approximate cost of repairs. The numbers are from Internet and for some are total of labor+parts. Not sure about accuracy or YMMV.
Feel free to contribute or correct.
  • Water pump and cooling pipes- 900 (labor) 250 (part)
  • Timing chain, Tensioners and guides (labor hours anywhere from 15 to 20) - $3800
  • Front top strut mounts
  • Front sway bar bushings and ball joints wear - ? (a very expensive job) ($700 in parts)
  • Front control arms - 2,300 (set of 2)
  • Front shock absorber - 700
  • Sunroof rust - 3,500
  • Freezing door lock / cable - ?
  • Oxygen sensor malfunction - ?
  • AC compressor failure - $2,000
  • Steering rack replacement - $4,000
  • Leaking Rear Air struts - 1,500 (one)
Last edited by GGG; 09-03-2020 at 03:43 PM. Reason: Amend thread title at OP's request
The following 2 users liked this post by drake1980:
Ken Dreger (06-13-2021), QP7 (06-30-2023)
Old 09-03-2020 | 11:30 AM
NBCat's Avatar
The AJ-V8 has timing chains, not a timing belt.
Old 09-03-2020 | 11:37 AM
thierry_1500's Avatar
I don’t think all of these are so common...
A more appropriate title could be:
« List of common and uncommon XJ problems and cost to repair »
or
« List of known XJ problems and cost to repair »
Daneel227 (09-17-2020)
Old 09-03-2020 | 11:53 AM
clubairth1's Avatar
Drop the rear air struts. They are not a common failure.
AC also not common.
Really should be listed in order of probability. So put the water pump first.
Outside of that nothing stands out? Timing stuff is year dependent as changes were made as time went along.
Maybe add front top strut mounts? We are seeing more of these with age and miles.
Ken Dreger (01-09-2024)
Old 09-07-2020 | 08:05 AM
leadfoot4's Avatar
Isn't there some issue with cooling hoses, on "early" XJs, with the V-6?
Old 09-07-2020 | 11:41 AM
Nedoerr's Avatar
What year and engine are we talking about? The issues became less with newer models.
Can add the sun shade motor/ guides/ anti-rattle kit - I think it was $1400.
Sticky buttons - lots of elbow grease
supercharger coupler/ snout - ~ $1000
Vacuum pump oil leak - $???
Sunk coolant reservoir float - ~ $350
Fuel injector clogged - ~ $400
Ken Dreger (11-27-2021)
Old 09-08-2020 | 07:13 AM
leadfoot4's Avatar
If you're referring to my post, the car is a 2016. My dealer's sales manager made me aware of the problem, and told me to "be prepared",,,,,
Old 09-08-2020 | 10:55 AM
Nedoerr's Avatar
The coolant hoses in general are prone to leaks in this car. The hoses were “rerouted” somewhat to reduce leaks. I think that was around 2016. I did mine at an independent shop and the price wasn’t too awful. As it was part of a larger service I don’t know the exact cost, but would guess around $1000 including a new water pump.
Old 09-08-2020 | 12:50 PM
Rummy636's Avatar
Lol hoses weren't rerouted. They went from a two-piece formed together design to a single molded pievce design. They always leaked through seam in which the two pieces were melted together.
The following 2 users liked this post by Rummy636:
calcareer (09-11-2020), Ken Dreger (01-09-2024)
Old 09-08-2020 | 01:29 PM
Nedoerr's Avatar
Im referring to the attached list of parts; call it what you'd like.
The attached file is from post number one here, where he details the update list pretty clearly.
https://www.jaguarforums.com/forum/x...s-list-177921/
All the best.
File Type: pdf
Old 09-09-2020 | 07:50 AM
leadfoot4's Avatar
$1000 to replace a faulty design by the manufacturer, and replace a water pump that on a Ford or Chevy, would last 20 years, or 200,000 miles. WOW....................
Old 09-10-2020 | 09:48 AM
clubairth1's Avatar
Yes if you need to pay for service it's very expensive. I can only own my 2014 XJR because of this list and I try to DIY the repairs.
Otherwise just too expensive.
Old 09-11-2020 | 12:19 PM
leadfoot4's Avatar
I agree, but one of the issues that I've incurred over the years, by doing as many repairs as possible by myself, is a couple thousand dollars in "specialty tools", that are car specific, and most likely, used only once.....
Old 09-12-2020 | 12:30 PM
clubairth1's Avatar
The only thing I have that's Jaguar only is SDD. But I had a spare laptop and the software was free but did take an awful lot of time to get it set up and working.
The Mangoose cable was about $60. Other than that I can't think of any special tools? I just use my regular hand tools but I have not done anything real technical like the timing chains as I do see a number of specific tools for that repair.
These modern cars have forced me to purchase an oil extractor and a fluid pump to help with servicing the transmissions,rear ends and AWD gear boxes. Many times there is no drain plug and I just don't believe in "lifetime" fluids. I change them all! That extractor has made difficult jobs a breeze!
Old 09-17-2020 | 03:33 PM
Daneel227's Avatar
Your list of "known XJ problems" is based on what? I never had any of these problems with my 2005 XJ8L. I replaced it at 117,346 miles due to it being totaled in a parked car accident. I currently have a 2014 XJL Portfolio AWD and have not encountered any of your "known XJ problems." Please share with the forum your source verifying this list of "known XJ problems." Thanks.
Old 09-17-2020 | 08:03 PM
Nedoerr's Avatar
Some of this stuff is well known (just use the search feature), some is not common, and some is not a flaw. Most importantly though, it all depends on the year and engine of the vehicle.
For example a 2014 will doubtfully have the sunroof rust or rattle as those were improved prior to 2014. Sticky buttons were allegedly dealt with in 2016. Timing chain tensioners were improved somewhere around 2013/2014. NA engines don’t have SC couplers. And my 2010 doesn’t have stop start batteries to deal with. So discussing “common” issues is difficult when they are not common to all models.
The stuff I don’t consider common, or that is not a flaw:
- suspension wear (wear and tear items aren’t really issues, except perhaps the strut mounts)
- AC condenser
- oxygen sensor malfunction
Another couple items to add though are:
- broken seat heater piping
- speaker wire rattle in the doors
Old 09-17-2020 | 08:26 PM
Grizzley1's Avatar
Default A better question
[QUOTE=clubairth1;2284363]Drop the rear air struts. They are not a common failure.
AC also not common.
A better question would be at what mileage should the timing chain be changed?
Unclereggie
05-02-2024 07:25 AM
Stuart S
01-23-2024 07:23 AM
pologuy
10-23-2019 11:50 PM
my1fant
08-12-2019 01:14 PM
2fast4u
02-10-2017 10:40 PM
Quick Reply: List of known XJ problems and cost to repair
