XJ ( X351 ) 2009 - 2019
Looking for exact location of hood switch on XJL
Old 11-05-2018 | 06:18 PM
Jay Govan's Avatar
Default Looking for exact location of hood switch on XJL
Having continuous open hood warning light on dash. Can someone help me locate the switch?
Thanks in advance
Old 11-06-2018 | 03:30 AM
xdave's Avatar
The switch is in the left hand latch mechanism, and can be accessed by removing the shroud. (C1PL25)
They are a common failure point. If removing the latch to clean/check/replace it is too much effort, or you need a quick way to lock the car, you can just dead short that connector out with a piece of wire pushed into the connector.
Nedoerr (05-10-2023)
Old 11-08-2018 | 11:44 AM
Nexsen's Avatar
Thanks. But is C1PL25 the switch to short or the shroud removed? A lot of connectors are shaded in purple.
Old 11-08-2018 | 02:01 PM
xdave's Avatar
Apologies, my message was a bit confusing there.
C1PL25 is the connector. It is plugged into the right hand side of the bonnet/hood latch mechanism where the tip of the arrow is.
You need to remove the plastic cover from the front of the engine bay (they are fitted with torx screws on the X351) then you can access the connector to remove it.
Then short between the two female pins on the connector to make the car believe the switch is closed.
Once you have exposed the latch it is worth checking to see if it is just stuck, and that the connector itself was securely fitted.
Old 11-10-2018 | 11:26 AM
Nexsen's Avatar
Thank you. I should be able to solve this problem with the excellent information you have provided. I appreciate it very much.
djdex
04-19-2024 05:07 PM
Foosh
01-11-2021 02:32 PM
Ubad2
02-18-2018 12:01 PM
thomash85715
XJ40 ( XJ81 )
04-21-2011 12:25 AM
hlgeorge
05-05-2010 09:29 PM
Quick Reply: Looking for exact location of hood switch on XJL
