Low battery and shaky XJ
I think I have traced my intermittent problem with feeling like I am driving on bricks to it does it when the battery is low. In fact, I think the lower the battery, the worse the vibration. You can actually see it in the wheel. When it does it, it is consistent across the RPM range and at all speeds.
Is there anything that would cause this to happen with a low battery? This is not an alignment or balance issue.
Louenigma
09-07-2008 07:36 AM
