Low Washer Fluid Warning - Leak?
I suspect that my 2013 XJ either has a cracked washer fluid reservoir, bad hose, or loose hose connection. The low washer fluid warning light on the right side of the instrument panel lights up about a day or 2 after I have repeatedly refilled the reservoir even though I have not used the washers.
Anyone else have this happen?
I'll let the dealer fix it since my car is still under warranty. Out of curiosity, does anyone know how to troubleshoot this to determine exactly where it is leaking from? Can't see much from on top of the engine.
Stuart
Stuart
Stuart
Stuart
I had a similar problem on my XF.
It turned out that one of the headlight washer hoses had become unclipped from the headlight.
You can just see the end of the disconnected hose if you look real hard down the back of the headlight, dunno about an XJ though.
Difficult but not impossible to reconnect without removing any parts, but you need small and nimble hands, again that's for an XF, dunno about an XJ.
If not the reservoir, then the headlamp washer is usually the culprit, esP; if your leak is in front of the wheel.
You can get your hand on the inner washer arm via the engine compartment if you don't have too thick arms/hands (position your other hand, on the outside of the washer, it's then easier to find .
You can also insert a phone and take some pictures/videos/
Usually you'll feel/see humidity and/or quite some dry deposits on the inner arm.
BR,
Thierry
BR,
Thierry
Stuart S (03-27-2020)
