Mina Gallery intake tube kit ?
Does any one have this kit installed on an XJR? I am interested if there is any noticeable difference in noise or performance. Not really concerned with performance aspect as much as id like to here the supercharger a bit more.
Jaguar XJ V6 Supercharged Performance Intake Tube Kit - Mina Gallery Inc
Received 3,209 Likes
One main benefit - the top of the supercharger runs considerably cooler with the engine cover removed, tested and proven by a couple of members on the F-Type forum.
Cooler intake air = a little more power and less chance of "heat soak" where the ECU pulls the timing and over-fuels (to cool the cats), resulting in a massive loss of power.
I have run my F-Type with the cover off for two years and not a single problem.
I put the TCP intake (very similar to the Mina) and K&N filters on my old XFR and I really could not detect any performance improvement at all.
The stock intake and air filters flow very well, at least enough to extract the maximum possible from the existing tune and SC boost.
bfarrell (07-15-2019)
Slightly off-topic, but since I was reminded by the pictures of the hood(bonnet)...if you remove the hood insulation and the rubber weatherstrip at the rear end of the hood (nearest the windscreen), you'll vent a lot of heat. It behaves as if the hood has been shimmed up. I can see the rippled air pouring out while moving slowly or stopped. Not sure how much of a difference it ultimately makes but less heat under the hood can't be bad.
