Misfires when warms up 2012 v8 NA
Hey guy back again. So I was driving the car at highway speeds. When I went park the car it started misfiring. Things that checked and errors below
Checked
Coils
Spark plugs
Fuel pressure
Vacuum leaks
These all above are fine
Errors
coils cylinder (b,d,f,h)
Sometimes it gives error for throttle body.
Any ideas will be appreciated
Checked
Coils
Spark plugs
Fuel pressure
Vacuum leaks
Errors
Your description reminds me of when one of the HPFPs in our XJ failed.
Search existing posts for HPFP, and you will find much descriptive info that won't be re-written here.
AND since it already exists in previous posts, you don't have to wait for replies to your questions - they've already been asked & answered.
Received 2,636 Likes
@Abbas_ahmd, kindly provide some background information:
- Vehicle MY
- Current kilometres/miles showing on the odometer
- Is the MIL on, and if so what DTCs are stored?
- What is the fuel pressure during the misfire event(s)?
- What is the ambient temperature during the misfire event(s)?
Based on my personal experience with the AJ133/126, the ignition coils are very rarely the problem.
When all the misfires are on one cylinder bank (Bank2), check the wiring loom and connectors for damage. It may also be necessary to perform a pin test for continuity from the Engine Control Module (ECM) to the injectors.
Here is a link to the AJ133/AJ126 Training Course:
https://www.dropbox.com/s/k214bnpsi2...ining.pdf?dl=0
Here is a link to the X351 Workshop Manual:
https://www.dropbox.com/s/jife7kkbcl..._2014.pdf?dl=0
Refer to page 7454 of the Workshop Manual for DTC explanations.
Here is a link to the Electrical Diagrams file:
https://www.dropbox.com/s/6zseatxlrc...22231.pdf?dl=0
Refer to section 310-01 (page 63) for Fuel Tank & Lines schematic diagrams.
Wow NBCAT. Above and beyond with the help and support! This is why this forum is awesome.
George05 (06-11-2023)
So changed the coils that came off from the engine it is much better then before but still misfires search continues......
Update
Coils changed
Injectors changed
Plugs changed
Still same issue as it warms up starts to misfire
Am really stuck on this now
just don't want to keep putting the money on it like this
Remaining I guess is fuel pump and throttle
In last will check the timing
As cold starts are fine till it reach the middle temperature niddle
My guess is throttle body
As when warmed up the car starts to misfire on idle maybe the position sensor is acting up
Other idea is hpfp but then it should not do this on cold start
By cold start mean the car is in Dubai and weather is very hot here so its not like really a cold start and car gets to running temp really fast.
In the last I think of timing but if timing was out it shouldn't be fine on the cold start
Coils changed
Injectors changed
Plugs changed
Good luck with finding the cause - it looks like it's getting quite expensive & time-consuming.
I did find the post gone through it. So here what's happening is that car warms up fine and stabilize for few mints but then suddenly starts misfiring alot with back fires. It's bit confusing for me however I will change the fuel pump now. And btw there is no cat in the car but that shouldn't be causing it as it was running fine.
I will report back after changing the fuel pump
Have any of you replaced the HPFPs yourself? - Jaguar Forums - Jaguar Enthusiasts Forum
carefully, you would notice that our XJ ran fine UNTIL it warmed-up to operating temperature.
This sounds like what you're describing, and what is confusing you.
However, other characteristics that you're seeing but not describing might be leading you away from an HPFP failure.
And you say you will change "THE" fuel pump.
Which one?
There are THREE fuel pumps in this car.
OK,
I maybe wrong on this, but here is my understanding of how the AJV8 comes up to operating temp, and what happens afterwards;
The start initiation is pre-programmed, the engine will race to 1250ish rpm, and then, in stages, back down to 650-700.
Once that process is complete, the engine (ECM) will start it's search for CAN BUS data. (Temp, O2, MAF, TP, Gear, Torque demand, etc, etc, etc). If one of those is out, the engine will spit rabbits.
Go for the cheapest things first;
Clean both MAFs (10 mins, $5)
Clean the TB (15 mins $10)
You also mentioned that the car doesn't have Cats, change the downstream O2 sensors, they are either cooked or clogged.
wombat
wombat
