XJ ( X351 ) 2009 - 2019
My Jaguar XJL SuperSport
Old 12-03-2018 | 06:13 AM
Geoffrey Fake's Avatar
Default My Jaguar XJL SuperSport
Hello
I am doing some mods in my jag, but I need help
here a presentation of my jaguar XJ L SuperSport Diesel, that I bought the 21st November, it was 69000km and all followed by Jaguar Garage in Essen.
https://www.jaguarforums.com/forum/n...mbourg-211197/
My first mode was exchanging the Nav system
I replaced the old one AW93 10E889 BJ to the new one DW93 10E889 BD
All works, massage seats, air'con ventilation seats front and back, TV DVD dual screen etc all good, only one thing doesn't work, the map on the cluster, I have just the name of the street.
My other Mods is changing the Interior lights by LED OSRAM ( dimming lights) it did a big improvement
bought the SET here - https://www.ebay.de/itm/Jaguar-XJ-X3...frcectupt=true
And of course, treated the Leather seat dashboard and the headliner as it is completely in leather, the finishing is awesome, I use this, very easy to apply and the result is astonishing
I took some scratches out from the center console with this ( plastic and metal) I use it normally for my watches
the result it is not bad
Now My QUESTION
I would like to know how can I do, to have the Mirror lamps replaced by LED
how to get access to it?
Thanks a lot
My car from outside next to my summer car
XJ8JR (12-03-2018)
Old 12-03-2018 | 02:20 PM
XJ8JR's Avatar
I never thought to use Cape Cod Cloth on the console. Thanks for the tip.
Old 12-04-2018 | 02:55 AM
EmmanuelTam's Avatar
Hi Geoffrey,
Both your Ghibli and XJL look awesome. I did not know Diesel version also have supersport trim.
I am no expert, I just so happened to have a set of repair manual. Hope this is what you are looking for.
Old 12-04-2018 | 07:51 PM
Originally Posted by EmmanuelTam
Hi Geoffrey,
Thank you so much
it worked, I removed the mirrors turning them to the side an applying a bit of force with my fingers and they pop out, then with a screwdriver, after a few tries I understood the thing, you must apply quite a bit of force and push down the clip of the light
the second one was then very easy, I installed the LED lights and it is much better
I will do pictures later on, as it is starting rainung
Thank you again
Old 12-04-2018 | 07:52 PM
I have a question,
how to see the Hidden menu on the cluster of the XJ ? what is the procedure?
Thank you
JNB
01-15-2013 09:44 PM
MarcusXFR
10-12-2012 09:07 PM
jaguarnews
04-02-2012 01:34 PM
LETAP007
07-30-2011 12:31 PM
