My XJ Sounds Like An F-Type Now!
Johncy2000 (10-03-2015)
He already posted a video on YouTube in his earlier thread:
https://www.jaguarforums.com/forum/x...-flyby-150903/
https://www.youtube.com/watch?v=w0RM...ature=youtu.be
Sounds nasty!
Sounds nasty!
erikasius22 (10-09-2015)
If you are getting popping out the exhaust, they are not doing it good enough. The popping is the unburnt exhaust finally reaching some air and being able to complete the combustion process.
I like the sound, but the popping would get to me. But, this is a personal preference. Some people like the loud exhausts. I am after something that sounds mean, but doesn't make it so you can't talk. I save the loud exhausts for something like a 23 T-bucket that has insane power to weight ratio and will pass just about anything on the road without really trying and will let you know it is coming through.
The following 2 users liked this post by XJsss:
JagMadeXJ (12-08-2015),
Johncy2000 (10-04-2015)
Johncy2000,
Since you're in California, I presume that you are already aware of the risk of being ticketed for violating the noise limit of 95dbA. Knowing the law and the enforcement guidelines may help you find ways to minimize or avoid that risk.
The complete California statute governing exhaust systems is here: Codes Display Text Extracts of relevant sections are below.
California Vehicle Code 21750. (Adequate muffler required)
(a) Every motor vehicle subject to registration shall at all times be equipped with an adequate muffler in constant operation and properly maintained to prevent any excessive or unusual noise, and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device.
A violation of this section is a misdemeanor.
Vehicle Code 27151. (Modification of exhaust systems)
(a) No person shall modify the exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor of the vehicle so that the vehicle is not in compliance with the provisions of Section 27150 or exceeds the noise limits established for the type of vehicle in Article 2.5 (commencing with Section 27200). No person shall operate a motor vehicle with an exhaust system so modified.
(b) For the purposes of exhaust systems installed on motor vehicles with a manufacturer’s gross vehicle weight rating of less than 6,000 pounds, other than motorcycles, a sound level of 95 dbA or less, when tested in accordance with Society of Automotive Engineers Standard J1169 May 1998, complies with this section. Motor vehicle exhaust systems or parts thereof include, but are not limited to, nonoriginal exhaust equipment.
The complete California statute governing noise limits is here: Codes Display Text
Here are the CHP enforcement guidelines:
If this has been helpful, please press at the bottom right.
Stuart
CHP Bulletin NO.98-100
Excessive Noise Enforcement Passenger Vehicles, Light Truck and Motorcycles
The California Highway Patrol, Commercial vehicle Section, has received many inquiries about excessive noise emitted by passenger vehicles, light trucks and motorcycles. Enforcement personnel and the public have inquired regarding enforcement of the Vehicle Code sections pertaining to excessive noise emitted by these vehicles.
Excessive Noise is primarily a nuisance issue rather than a safety concern, and determination of excessive noise is subjective. For this reason, enforcement personnel are to exercise sound professional judgment in making a determination of violation. The following guidelines and attached question and answer sheet ( attachment A) provide guidance to enforcement personnel regarding appropriate enforcement procedures.
Enforcement Guidelines
The only drivers who should be cited are those whose vehicles:
1) are not equipped with a muffler
2) clearly emit an offensive, harsh, excessive noise, or
3) have a clearly defective exhaust systems (holes, leaks, etc.)
Clearing Citations
When clearing excessive noise citations issued by the CHP or allied agencies, personnel are to consider exhaust systems in compliance if they incorporate a reasonably effective muffler, do not emit an offensive, harsh, excessive noise, and appear to be in good repair.
Attachment A
Q1. Doesn't the VC require a muffler on every vehicle?
Yes. Section 27150 VC requires that every motor vehicle subject to registration be equipped with an adequate muffler. There are no exceptions -all vehicles must be equipped with a muffler, as defined in Section 425 VC. A turbocharger is not considered a muffler.
Q2. Aren't all exhaust system modifications prohibited?
No. Section 27151 VC prohibits the modification of the exhaust system to amplify or increase the noise emitted by the vehicle, making the vehicle not in compliance with Section 27150 VC or exceeding the noise limits established in Sections 27201-27206 VC. Section 27151 VC does not prohibit all modifications to an exhaust system. It also does not prohibit all modifications that increase the noise level of the exhaust system over that of the original, factory installed exhaust system (as it did until 1980) It only prohibits modifications that result in a noise level higher than those specified in Sections 27201-27206 VC. Accurately determining compliance with Sections 27201-27206 VC for enforcement purposes is generally impractical. Enforcement personnel must make an informed professional evaluation to determine if excessive noise statutes are being violated.
Q3. Do I have to actually listen to a vehicle to cite it for a violation of either Section 27150 or 27151?
Yes. Drivers of vehicles should not be cited for violation of either Section 27150 or 27151 VC unless the officer has personally listened to the vehicle in operation. This can be either under actual driving conditions or with the vehicle stationary and the engine running. Even if the officer has inspected the exhaust system and does not see a muffler present, the officer should listen to the vehicle. The purpose of this is to be sure that the exhaust system does not incorporate internally baffled pipes or other components that meet the definition of a muffler. There are so specifications which state required configurations or minimum dimensions for mufflers. A vehicle that does not visually appear to be equipped with a muffler, but does not emit excessive noise, should be deemed to comply with sections 27150 and 27151VC.
Q4. Does an aftermarket replacement or modified tailpipe or muffler tip constitute a violation of section 27151 VC?
No. Section 27150 VC prohibits the modification of exhaust systems to amplify or increase noise. The officer would have to establish that the modification increased the noise emitted by the vehicle by listening to the exhaust. In general, exhaust system piping, tubing, fittings, cosmetic tips or other passive devices placed behind the muffler have minimal impact on exhaust system sound levels.
Q5. Since Section 27150 requires that the muffler prevent excessive and unusual noise, can the driver of a vehicle be cited for violation of Section 27150 if it emits a sound different than the original factory installed muffler?
No. The prohibit against unusual noise refers to noises that are unusual for motor vehicles. Noises that may be unusual for a particular for other motor vehicles, should not be considered in violation, provided the noise excessive.
Q6. Aren't all modified exhaust systems unlawful under pollution control laws?
No. Current pollution control laws regarding aftermarket exhaust systems are quite complex, but do permit the installation of variety of aftermarket and "exempt" systems. Due to the complexity of modern pollution control systems and the laws governing them, the CHP does not provide technical training in this area. Enforcement of pollution control laws is the responsibility of the Bureau of Automotive Repair through the "Smog Check" program.
Q7. What are the noise levels specified in Section 27201-27206 VC? Can these be used to cite loud vehicles?
No. Section 27200 VC prohibits the sale of new motor vehicles that exceed the noise limits specified in these Sections. The specified noise limits (80dB-A) for all new cars, pickup trucks, vans and motorcycles apply only to new motor vehicles, under full throttle acceleration tests, measured 50 feet from the test vehicle, as specified in Section 1040-1044, 1046 and 1047, title 13, California Code of Regulations (13 CCR) These noise levels and the specified test methods apply to manufacturers and new car dealers only, for new vehicle certification purposes, and may not be used for enforcement purposes against vehicles being operated on public roadways. The CHP is not aware of any significant violation of Section 27200 VC by vehicle manufacturers or dealers.
Q8. What are the noise levels specified in Section 23130 and 23130.5 VC and how can they be enforced?
Section 23130 and 23130.5 VC specify noise standards for vehicles operating on the highway, and are intended for use in actual traffic conditions. The limits of Section 23130 apply under all conditions of grade, load acceleration and deceleration. The lower limits of Section 23130.5 apply only to relatively level roadways and under conditions of relatively constant speed. They specifically do not apply to areas of congested traffic that require noticeable acceleration or deceleration, or within 200 feet of an official traffic control device or change in grade. Although these sections were intended for use in actual traffic conditions, the complexities of noise testing require the be conducted in a relatively large open area free of other vehicle and large sound-reflecting objects. This makes in-use vehicle noise testing in most developed areas impractical, where noise complains are most likely to occur. The CHP currently does not provide either the instrument or training necessary to conduct vehicle noise testing. Enforcement using Section 27150 or 27151 VC is usually more appropriate and effective.
Q9. What is the exhaust noise test specified in 13 CCR? Can this be used for enforcement?
Section 1030-1036, 13 CCR, were intended to be used by Licensed Muffler Certification Stations as a means of detection if an exhaust system met the requirements of the Muffler Certification Program (When those programs were operational) They specify testing procedures for motor vehicle exhaust noise alone (as opposed to total vehicle noise) This procedure specifies a limit of 95 dB measured 20 inches from the exhaust pipe outlet with the engine operating in neutral, typically at speed of 3000-5000 rpm. It applies only to passenger vehicles. It does not apply to motorcycles or to vehicles over 6000 pounds gross weight.
Q10. Can this test be used in enforcement?
Not Readily. Although much simpler than the test methods specified in Section 23130 and 2310.5 VC, this test method still requires some technical expertise and a means to determine both the speed of the engine under test and the RPM at which maximum horsepower of the engine is developed, as well as sound level meter. The CHP does not currently provide either the instrument or training necessary to conduct exhaust noise testing. This test is useful, however, for determining if an aftermarket or performance exhaust system complies with VC requirements. It should be noted that the 95dB level, because it is intended as a simple "go-no-go" type of test, may permit exhaust noise somewhat higher dm those permitted under Sections 27201-27206 VC. An exhaust system that complies with the requirements of Sections of Section 1036d-1, 13 CCR, is deemed to comply with Sections 27150 and 27151 VC.
Q11. What happened to the Muffler Certification and the Licensed Muffler Certification Station Programs?
Funding for both programs were determined in 1979. There are currently no Official Muffler Certification Stations, no listing of certified mufflers and no formal mechanism in place to conduct objective vehicle or exhaust noise testing.
Q12. Can local authorities enact or enforce more strict ordinances regarding vehicle noise?
No. Section 21 VC makes the VC applicable and uniform throughout the state, and prohibits local authorities from enacting or enforcing any ordinance on the matters covered by the VC unless expressly authorized to do so. In-use vehicle noise is addressed in Sections 23130 and 23130.5 VC. There is no provision in the VC that permits local authorities to adopt additional noise limitations. Consequently, citations issued such ordinances are invalid.
Q13. Some aftermarket exhaust systems include documentation that the system has tested and found to meet the requirements of section 1036d-1, 13 CCR. Are those legal?
The CHP does not have the resources to independently verify manufacturer's claims, but is aware that some aftermarket exhaust systems do meet the noise levels specified in Section 1036 d-1, 13 CCR. An officer may consider such documentation in evaluating an exhaust system for excessive noise, both during the issuance of a citation and when clearing a citation pursuant to Section 40610b VC.
Q14. What type of enforcement action should be taken against vehicles emitting excessive noise?
Providing none of the disqualifying conditions listed in Section 40610b are present, the use of the CHP 281, "Notice to Correct" or checking the Dismissible Violation "Yes" box on the CHP 215, "Notice to Appear to Appear-Arrest Citation", would be appropriate for these violations.
Stuart
The following 3 users liked this post by Stuart S:
My current setup is:
Stock Cats----->Magnaflow 2.5" Xpipe Muffler----->Straight Pipe to Twin Tips Out Back
Johncy2000 (10-06-2015)
Got a 20% of coupon from Magnaflow. I'm going to buy this weekend but first want to confirm I'm buying the right muffler. Based of the pic you posted of the muffler I am to buy Magnaflow Muffler part#11386 a qty. of 2. What is the length of the straight pipes? Did you need any additional hardware??
Johncy2000 (12-09-2015)
It's not the "ghetto-ize" the car. I have a supercharger and over 480hp if people can't see the supercharged logo they will damn sure know when I step on the gas. Also the cruising speed is quiet so I'm not worry about the ghetto. The way I see it it's a luxury car that's fast, and I want it to sound a little mean and if you saw the video it sounds good not your traditional loud ghetto 95 civic that's only going 10mph waking up a neighborhood.
The following 2 users liked this post by JagMadeXJ:
Johncy2000 (12-09-2015),
LaCapitalRue (12-09-2015)
