XJ ( X351 ) 2009 - 2019
Nav split screen annoying
Old 12-27-2011, 10:59 AM
ozy's Avatar
ozy
ozy is offline
Default Nav split screen annoying
Randomly my navigation map view seems to go into split screen where it is showing me exits, etc. on the right. It does this when I just have the map on while I'm driving (i.e. no set destination).
I know what on-screen buttons to push to get it back to the full map mode, but then at some point it jumps back to the split screen.
Is there some setting I'm missing that I can turn on/off to stop it from going to the split screen mode? I just want to always see the full map and don't need the list of upcoming exits or whatever on the right.
Old 12-27-2011, 12:23 PM
HouTexJag's Avatar
The nav system automatically goes to the split screen showing the upcoming exits whenever you get on a freeway. Yes, it is annoying and there is no way to permanently defeat this that I know of. Not just a Jaguar issue--a friend of mine had the same problem in a Cadillac CTS.
Old 12-28-2011, 07:48 AM
xjb's Avatar
xjb
xjb is offline
This minor issue annoys the heck out of me, too. It would be great to see this issue addressed in a software update.
Old 01-05-2012, 11:04 AM
Holein1's Avatar
On the 2012, there is an icon on the lower left corner of the screen that you can select to turn on or off the split screen. It looks like a white rectangle. As previously mentioned, this can probably be addressed with an update.
Old 01-05-2012, 04:54 PM
HouTexJag's Avatar
Does this permanently turn off the split screen or just temporarily? You can push that button on the 2011's and it just comes back a little later if you are still on the highway.
Old 01-05-2012, 05:44 PM
Holein1's Avatar
I think it stays that way permanently. I'll have to double check on that; but, I'm fairl sure.
Old 01-08-2012, 04:52 PM
Holein1's Avatar
Nope. It appears that it reset itself to a split screen whenever you drive onto a new interstate or turn off the car. It is kind of annoying.
Old 01-08-2012, 07:05 PM
Fire34609's Avatar
ozy and xjb,
I have a 2011 xj and this little square is available on my screen too. It does seem to reset for interstae and expressway driving. I don't mind it personally.
Old 01-09-2012, 08:11 AM
xjb's Avatar
xjb
xjb is offline
Originally Posted by Fire34609
ozy and xjb,
Yes, I've always had the little square, too. I'm just (very, very mildly) annoyed that I have to push it every time. For me, the exit info is not as useful as other options. For other folks, it might be. That's why I hope for a software update to give us the option to not have it appear.
Old 01-31-2012, 10:55 AM
sbhtax's Avatar
Smile
There is a simple solution. From the main navigation screen, select Nav setup. Then select User Setup. The item called "highway information" needs to be turned off with a screen touch. Once turned off the split screen on freeways and interstates will not appear.
Steve H
The following 5 users liked this post by sbhtax:
barryf43 (01-31-2012), HouTexJag (01-31-2012), Jffcurt (02-19-2012), teachdocs (02-09-2012), xjb (02-19-2012)
Old 02-19-2012, 07:23 AM
xjb's Avatar
xjb
xjb is offline
Worked perfectly. Thanks!
Steve H
Finbarr1975
09-16-2023 02:52 PM
Paora
02-04-2021 12:36 AM
Finbarr1975
10-04-2015 05:32 PM
10 XF Premium
10-02-2015 09:22 PM
Quick Reply: Nav split screen annoying
